2009-09-27, 12:01
Im not sure if my system should be able to cope or not here are the specs..
Ubuntu 9.04 Mini install
XBMC SVN (23185)
Gigabyte GA-73PVM-S2H Motherboard
Onboard 7100 nVidia with 256meg memory (shared)
2GB DDR2
Intel Core 2 Duo 2.1
1TB HDD
Screen Res - 1920x1080
nVidia 185 Drivers
Running Aeon hitcher skin, all the interface works fine and 720p stuff but 1080p stuff skips frames and some 1080p films only play at 15fps
I know VDPAU mode isnt supported (Anyone know if Nvidia will be adding the 7xxx series to it?)
But should my machine not be fast enough to handle 1080p films in software? Is there anything I can try to improve the performance, I dont have anything extra running in the background the machine boots directly to XBMC
XBMC SVN (23185)
2GB DDR2
1TB HDD
nVidia 185 Drivers
