Full Version: Is there a Media manager that supports a Spanish Scraper?
Hi all,
I have a big library of kid movies in spanish for my daughters and would like to know if there is any media/jukebox manager that allows me to the info about those movies in spanish to display it in XBMC (Info, fanart, thumbnails, etc.).
I use Media Info Plus for my english movies and it works perfectly but when I try to use it with any movie with spanish title it doesn't work. (Is there any way to force it to use an spanish scrapers?)
The XBMC film affinity scrapper works great Ill like to have a program in my PC to get that info.
Any help suggestion will be greatly appreciated.
Thanks!!!!
Hi!
I was looking for the same thing, but I didn't find anything. However, this trick may help you:
In xbmc: Preferences>Video>Library> Export Library
This way you can put nfo's files in the hard drive. So, you can scrape with the filmaffinity scraper and then use the export function.
Later you can try to use another program (ember, media info plus...) to... touch some things if you need.
Cheers
