2009-09-27, 19:19
Hello all - after upgrading to SVN revision 23164, I am now unable to select DVD/ISO menu items. When the "select" button is pressed, the OSD displays (as if the video was playing) rather than simply selecting the DVD menu item. In the stable build, selecting items in a DVD menu would not bring up the OSD.
Currently, I'm running Ubuntu 9.04 i386 on an ASROCK ION 330, using a Wii Remote through the XBMC Wii remote event client for a remote. I'm also using the default PMIII HD skin. I had the same problem on another PC I was using as a media center (also running 9.04 and using the Wii remote).
Incidentally, I have failed to find a keymap.xml file anywhere in my ~/.xbmc/ directory - so I have not been able to change the default Wii remote keymap. That said, I don't believe changing the keymap would help, as the default mapping is only to "Select".
Any thoughts would be greatly appreciated!
Log File: http://pastebin.com/m152f2a59
Solved! See Thread:
http://forum.xbmc.org/showthread.php?p=409531
Solved! See Thread:
