Full Version: uPNP problems sometime after rev21142
Pages: 1 2 3 4 5 6
I tried 28614 (nightly build of 3/16/2010 from http://www.sshcs.com/xbmc) and it still crashes:
20:04:48 M: 42430464 DEBUG: CApplication::OnKey: 11 pressed, action is 7
20:04:48 M: 42594304 DEBUG: CGUIMediaWindow::GetDirectory (upnp://)
20:04:48 M: 42594304 DEBUG: ParentPath = []
20:04:48 M: 41984000 DEBUG: CFileItemList::Sort, sorting took 0 millis
20:04:50 M: 41779200 FATAL: EXCEPTION_ACCESS_VIOLATION (0xc0000005)
at 0x0020c9ee
Is there a chance that this problem will be solved in the near future?
Same issues for me. I'm back to using 17349. Now if I could just fix the multiple failures before playon will actually play a video I'll be back in business. Hopefully the new path for XBMC on Xbox will result in some of these issues getting fixed.
Just tried the 28766 nightly, still the same issue - http://pastebin.com/FUNU3cpH
I'm finding the 26941 T3CH build works fine for me. I had tried the 28472 T3CH one but that also had the issue.
n8mack33 Wrote:Same issues for me. I'm back to using 17349. Now if I could just fix the multiple failures before playon will actually play a video I'll be back in business. Hopefully the new path for XBMC on Xbox will result in some of these issues getting fixed.
Just wanted to add my support to getting the uPNP problem fixed on the Xbox builds.
As for n8mack33, I have been using Playon.TV for the last month or so. It took a lot of tinkering, but finally got it working well for me. It plays Netflix, Hulu, Comedy Central, etc. to both of my Xboxes without so much as a hickup.
I ended up with the following configuration for both boxes:
T3CH XBMC 2009-06-01 9.04.1-FIXED-Babylon (SVN:20848)
Set DVDPlayer as the default player using advancedsettings.xml
Set the Network Cache to 4096k
spdabbs Wrote:Just tried the 28766 nightly, still the same issue - http://pastebin.com/FUNU3cpH
Weird: Doesn't look like there are any relevant changes between the revisions you mentioned..... You're sure about the rev-numbers?
how did you change the cache settings?
arnova Wrote:Weird: Doesn't look like there are any relevant changes between the revisions you mentioned..... You're sure about the rev-numbers?
My bad, being a n00b - SVN:20848 is the one that works (dawned on me upon seeing the T3CH date for it)!
Dam just upgraded and upnp is crashing.... which doesnt help with my PS3MS setup Sad
Built on Mar 15 2010 (SVN:28565, compiler 1310)
08:41:58 M: 36225024 NOTICE: starting upnp server
08:42:01 M: 36028416 DEBUG: CApplication::OnKey: 167 pressed, action is 4
08:42:07 M: 36028416 DEBUG: SECTION:UnloadDelayed(DLL: Q:\system\ImageLib.dll)
08:42:08 M: 37117952 DEBUG: CApplication::OnKey: 167 pressed, action is 4
08:42:09 M: 37117952 INFO: XCURL:Big GrinllLibCurlGlobal::CheckIdle - Closing session to http://www.google.com (easy=00C8D010, multi=00000000)
08:42:09 M: 37081088 FATAL: EXCEPTION_ACCESS_VIOLATION (0xc0000005)
at 0x0020c9ae
Is there anything I can do to help?.... tested latest nightly and its the same
Only thing that could help is that someone would finally figure out the *exact* revision it broke not just guesses or rough estimates..
ok - I'm off line today as we're having family easter and to be honest I wanna go to the pub!!! LOL!
But I have a free hour or so tomorrow so I'll get on it then Wink
I can enable the UPnP server on my Xbox just fine with revision 26941. This breaks with revisions 28472 and onwards.
joshuaali Wrote:I can enable the UPnP server on my Xbox just fine with revision 26941. This breaks with revisions 28472 and onwards.
There are (still) to many changes between those revs to isolate the problem...
i also have this problem but i just turn it off and use the smb share to acces my folders and files
Hmmm cant get any different builds.... T3CH site doesnt have them and sshcs seems to be having problems.. Sad
arnova Wrote:There are (still) to many changes between those revs to isolate the problem...
I played 'binary search' with sshcs's nightly builds.
Build 27258 works.
Build 27290 does not work.
http://trac.xbmc.org/changeset?old_path=...&new=27290
sshscs doesn't have any builds in between those two revisions.
Pages: 1 2 3 4 5 6
