Full Version: Watched status only shows in list views?
Hi there,
First off, awesome skin. It's my current favourite. However, I noticed the watched checkmark only seems to display in the List Views for both movies and tv. Is this normal? I rely on the watched status for TV shows especially and while I don't mind the list views, I like some of the others better. Is it possible to implement the watched status in the other views as well?
Thanks,
Kevin
would really like the same thing. watched status on wide icons (in tvshows) Smile
also, perhaps a "x New episodes" overlay next to it?
loving the skin apart from that Smile
I can add them to wide icons.
Views like icons and big icons have variable aspect ratios so it wouldn't look good having an overlay over the cover. Although I can add it to the infopane area, you just won't be able to tell whats watched at a glance unless you select it.
