2009-09-30, 10:44
Hi
I really like XBMC, thanks a lot for that great piece of software!
My problem:
I want to stream live-tv from a Dreambox to XBMC. I tried two methods on two different systems (Vista and XBMC Live), both didn't work.
Method one was using the Enigma2 Script found here at the forums. The script shows a list of the channels, so communication with the Dreambox seems to work. But when I try to start a stream it does not play anything.
Method two was creating a .strm file containing the URL to the streaming file. Same problem here.
I can play recorded .ts files in XBMC without any problem, it's only a problem with live-tv. Live-tv streaming works great using VLC so I don't think it's a Dreambox problem. I use the newest Gemini Project on the Dreambox and tried "XBMC Live" and XBMC for Vista.
Any suggestions? Thanks
My problem:
