Full Version: Turn off xbmc_crashlog
Hello there,
couldn't find related topic so I must ask for help.
As I use xbmc a lot and my PC is pretty old it often crashes.
I have noticed that my home directory is full of xbmc_crashlog files.
If this continues with this tempo in few months my usb stick will be full.
I know that I could manually delete those files, but is there a option to turn off
xbmc_crashlog?
Thx in advance...
This is by design. The goal was to get you to report the problems.
althekiller Wrote:This is by design. The goal was to get you to report the problems.
For windows, we do one dmp file per revision.
You could easily setup a cronjob to do this every few days.
https://help.ubuntu.com/community/CronHowto
Write up a little bash script to rm ~/xbmc_crashlog* or whatever the filename base is.
Make it executable and throw a call to in in crontab.
Thx for reply to all, appreciated Nod
hikaricore Wrote:You could easily setup a cronjob to do this every few days.
I wanted to avoid this, but now...
...I realize that this is the only way.
Thx for the tip Wink
Cheers all
