Full Version: Return the correct path to external players when in library mode
concerning http://www.xbmc.org/forum/showthread.php...post411613
the problem is that it is not possible to use an external player when in library mode because of the following issue:
when in library mode XBMC returns a musicdb-uri like
Quote:musicdb://3/411/5093.wma
which can't be used by external players
it would be nice if there i'll be some xml-tag or some new operator like {3}
for
Quote:playercorefactory.xml
which tells XBMC to return the correct path
The correct path can be computed by the following database query
SELECT path.strPath, song.strFileName from song,path where idSong=NUMBER RETURNED IN URI and path.idPath=song.idPath;
which in the above case would be:
SELECT path.strPath, song.strFileName from song,path where idSong=5093 and path.idPath=song.idPath;
this indieed returns the correct path which any external player should be able to use.
(for unix spaces need to be escaped with
of course)
the output of the above query is:
Quote:/media/LACIE/multimedia/audio/Eigene Musik/The Beatles/Anthology 1 Disc 2/19 You Know What to Do.wma
and as already stated this is indeed correct
EDIT as temporary hack until the suggested feature is implemented i wrote a little script which will do that:
DATABASE_URI="$1"
#TEST STRING WHEN     IN LIBRARY MODE: DATABASE_URI="/musicdb://3/411/5093.wma"
#TEST STRING WHEN NOT IN LIBRARY MODE: DATABASE_URI="/media/LACIE/multimedia/audio/Eigene Musik/The Beatles/Anthology 1 Disc 2/19 You Know What to Do.wma"
DATABASE_URI_PREFIX=`echo $DATABASE_URI | sed "s/:.*//g"`
if [ "/musicdb" = $DATABASE_URI_PREFIX ];
then
  echo "XBMC IN LIBRARY MODE"
  DATABASE_SONGID=`echo "$DATABASE_URI" | sed "s/\/.*\///" |  sed 's/\(.*\)\..*/\1/'`
  DATABASE_PATH="$HOME/.xbmc/userdata/Database/MyMusic7.db"
  totem "`sqlite3 -separator "" $DATABASE_PATH "SELECT path.strPath, song.strFileName from song,path where idSong=$DATABASE_SONGID and path.idPath=song.idPath;"`"
else
  echo "XBMC NOT IN LIBRARY MODE"
  totem "$DATABASE_URI"
fi
you may replace totem by any player you wanna use
cheers
