The reason why I post it here,cause I think there has to be adjustment made on the skin.
But maybe I am wrong and need to contact the script/plugin makers.
If that is so please let me know
With skin Rapier program plugin :Notepad doesn't work.
and with script:mytv you can't see which item is marked on settings menu.
However I don't have this problem with other skins.
Project Mayhem III script:mytv
Rapier script:mytv
Apple movie trailers, doesnt work for me. It freezes and gives me some crap about too many failed items.
on script:
XOT-Uzg font/text isn't visible on most places.
example look it should be on main menu of XOT-Uzg
on Rapier.Under each logo there should be text
I can confirm those problems with scripts....
That XOT-uzg is missing the text in the most important place.... the TV-shows.
No other skin does this...
frater Wrote:I can confirm those problems with scripts....
Any news on this bug. I currently stops me from using Rapier as my default skin which is sad since I like it a lot.
scarfa Wrote:I'll check it out.
add
PHP Code:
<default type="label">
<textcolor>DefaultColor</textcolor>
</default>
in skin/Rapier/720p/Default.xml and restart the XBMC
it should look like this:
PHP Code:
<includes>
</default>
<default type="button">
<width>200</width>
<height>35</height>
<font>ButtonFont</font>
<textcolor>ButtonColor</textcolor>
<focusedcolor>SelectedColor</focusedcolor>
<disabledcolor>DisabledColor</disabledcolor>
<align>center</align>
<aligny>center</aligny>
<textoffsetx>5</textoffsetx>
<texturefocus border="5">button-focus.png</texturefocus>
<texturenofocus border="5">button-nofocus.png</texturenofocus>
<pulseonselect>true</pulseonselect>
</default>
<default type="radiobutton">
<width>200</width>
<height>35</height>
<radioposx>-</radioposx>
<radioposy>-</radioposy>
<radiowidth>18</radiowidth>
<radioheight>18</radioheight>
<textureradiofocus>radio-button-focus.png</textureradiofocus>
<textureradionofocus>radio-button-nofocus.png</textureradionofocus>
</default>
<default type="togglebutton">
<width>200</width>
<height>35</height>
<alttexturefocus border="5">button-focus.png</alttexturefocus>
<alttexturenofocus border="5">button-nofocus.png</alttexturenofocus>
</default>
<default type="selectbutton">
<width>300</width>
<height>100</height>
<font>HeadFont2</font>
<selectedcolor>SelectedColor</selectedcolor>
<textwidth>240</textwidth>
<texturebg>-</texturebg>
<textureleft>arrow-scroll-left-nofocus.png</textureleft>
<textureleftfocus>arrow-scroll-left-focus.png</textureleftfocus>
<textureright>arrow-scroll-right-nofocus.png</textureright>
<texturerightfocus>arrow-scroll-right-focus.png</texturerightfocus>
</default>
<default type="spincontrol">
<width>28</width>
<height>28</height>
<font>HeadFont2B</font>
<textcolor>DisabledColor</textcolor>
<shadowcolor>ShadowColor</shadowcolor>
<align>right</align>
<textoffsetx>-5</textoffsetx>
<textoffsety>0</textoffsety>
<spinwidth>26</spinwidth>
<spinheight>26</spinheight>
<textureup>arrow-scroll-up-nofocus2.png</textureup>
<texturedown flipy="true">arrow-scroll-up-nofocus2.png</texturedown>
<textureupfocus>arrow-scroll-up-focus2.png</textureupfocus>
<texturedownfocus flipy="true">arrow-scroll-up-focus2.png</texturedownfocus>
<reverse>yes</reverse>
<subtype>page</subtype>
</default>
<default type="spincontrolex">
<width>400</width>
<height>35</height>
<spinwidth>18</spinwidth>
<spinheight>10</spinheight>
<font>DefaultFont</font>
<align>left</align>
<textureup>arrow-scroll-up-nofocus.png</textureup>
<texturedown>arrow-scroll-down-nofocus.png</texturedown>
<textureupfocus>arrow-scroll-up-focus.png</textureupfocus>
<texturedownfocus>arrow-scroll-down-focus.png</texturedownfocus>
</default>
<default type="edit">
<width>400</width>
<height>35</height>
<textwidth>390</textwidth>
</default>
<default type="sliderex">
<height>35</height>
<sliderwidth>105</sliderwidth>
<sliderheight>24</sliderheight>
<texturesliderbar>slider-background.png</texturesliderbar>
<textureslidernibfocus>slider-nib-focus.png</textureslidernibfocus>
<textureslidernib>slider-nib-nofocus.png</textureslidernib>
</default>
<default type="progress">
<width>400</width>
<height>12</height>
<texturebg border="2">scrollbar-background.png</texturebg>
<lefttexture>-</lefttexture>
<midtexture border="2">scrollbar-slider-horz-nofocus.png</midtexture>
<righttexture>-</righttexture>
<overlaytexture>-</overlaytexture>
</default>
<default type="scrollbar">
<height>400</height>
<width>14</width>
<orientation>vertical</orientation>
<texturesliderbackground border="2">scrollbar-background.png</texturesliderbackground>
<texturesliderbar border="2">scrollbar-slider-nofocus.png</texturesliderbar>
<texturesliderbarfocus border="2">scrollbar-slider-focus.png</texturesliderbarfocus>
<textureslidernib>-</textureslidernib>
<textureslidernibfocus>-</textureslidernibfocus>
<showonepage>false</showonepage>
<pulseonselect>false</pulseonselect>
</default>
</includes>
EDIT: changed "white" to "DefaultColor", thanks j0cke
Zeljko
Well there you have it. Thanks Amet.
I still can't see the text in XOT-Uzg after adding the code by Amet...
j0cke Wrote:I still can't see the text in XOT-Uzg after adding the code by Amet...
have you restarted the XBMC? or just reload the skin.
I got it working now.
I had to replace "white" with "DefaultColor" because ..skin/Rapier/colors/defaults.xml does not have a color name for "white"
j0cke Wrote:I got it working now.
Thanks for the correction, it worked fine on OSX with white. I changed white to DefaultColor in OP
Zeljko
