Full Version: Library not updating
My library has stopped updating TV Shows, Movies are fine but any new episodes i try and add just get ignored.
i.e. 24 S02E01 is there but I add S02E02 and it just acts like its not there...
If I delete MyVideos34.db it will update but I have to do this every time I want to add an episode and with as many TV/Movies as I have it takes a couple of hours Sad
Anyone got any idea, im running the latest SVN 23321.
I've also checked the permissons of MyVideos34 which are correct and I've also tried changing the scrapper i.e. MyTVdb to IMDB TV etc..
Ok well I'll half answer my own question in case anyone else gets this. I found this thread http://forum.xbmc.org/showthread.php?tid...ht=scraper
the problem was I was using a 3rd party scraper which generated .nfo so I tried to delete all the .nfo files and rescan in XBMC but this didnt work so I had to remove my .db file and then rescan.
Why does XBMC no detect the .nfo files are not there and update the database, why do you need to remove the db for it to work?
OK still having issues now with Movies not pulling down details... here is my log..
http://pastebin.com/d4485b03f
I've also tried another scraper but it seems like its reporting back no details when trying to scrap info but If i go to the address manually i.e.
http://api.themoviedb.org/2.0/Movie.sear...b854740ea9
for underworld all the details are there..
Nicoli I am also having this problem imdb is not scraping any info for me thumb, fanart etc. I am on a windows xp professional sp3 what would be my process to correct this as I noticed ezriderz is running off the xbox so I guess it would be different for me
Thanks in advance
Hopefully someone has an idea as to why its not working?
I've been looking at this all day. My log does not show anything suspicious at all. Everything is loaded properly, when I click scan for new contents, XBMC makes a scan of the full list, \once scanning of filepath was done, the process ends.
For some reason the XBMC scraper is not running after the scan. Could someone please point me to fix this problem. I recently upgraded my XBMC to the nightly svn build, seeing that movie library would not scrap and update, I uninstalled everything, deleted all db files, and installed a fresh new copy. Even after fresh install, I still cant do anything.
Please help!!!
21:35:25 T:3164 M:2245033984   DEBUG: Alloc resources: 1.27ms (1.18 ms skin load, 0.07 ms preload)
21:35:25 T:3164 M:2245033984   ERROR: Control 402 in window 10133 has been asked to focus, but it can't
21:35:25 T:4060 M:2245005312   DEBUG: thread start, auto delete: 0
21:35:25 T:4060 M:2245001216   DEBUG: VIDEO::CVideoInfoScanner::Process - Starting scan
21:35:25 T:1528 M:2244972544   DEBUG: thread start, auto delete: 0
21:35:25 T:1528 M:2244968448   DEBUG: Thread 1528 terminating
21:35:25 T:4060 M:2245001216   DEBUG: CMultiPathDirectory::GetDirectory(multipath://E%3a%5cMovies%5c/F%3a%5cMovies%5c/M%3a%5cMovies%5c/)
21:35:25 T:4060 M:2244997120   DEBUG: Getting Directory (E:\Movies\)
21:35:25 T:4060 M:2244997120   DEBUG: Getting Directory (F:\Movies\)
21:35:25 T:4060 M:2244997120   DEBUG: Getting Directory (M:\Movies\)
21:35:25 T:4060 M:2244997120   DEBUG: CMultiPathDirectory::MergeItems, items = 7
21:35:25 T:4060 M:2244997120   DEBUG: CFileItemList::Sort, sorting took 0 millis
21:35:25 T:4060 M:2244997120   DEBUG: Testing path: [000] F:\Movies\2 Fast 2 Fast 1080p\
21:35:25 T:4060 M:2244993024   DEBUG: Testing path: [001] E:\Movies\8 Mile 720p\
21:35:25 T:4060 M:2244993024   DEBUG: Testing path: [002] F:\Movies\12 Rounds 1080p\
21:35:25 T:4060 M:2244993024   DEBUG: Testing path: [003] E:\Movies\13 Going On 30 2004 720p\
21:35:25 T:4060 M:2244993024   DEBUG: Testing path: [004] M:\Movies\17 Again 2009 720p\
21:35:25 T:4060 M:2244993024   DEBUG: Testing path: [005] F:\Movies\21 2008 720p\
21:35:25 T:4060 M:2244993024   DEBUG: Testing path: [006] E:\Movies\27 Dresses 720p\
21:35:25 T:4060 M:2244993024   DEBUG: Testing path: [007] E:\Movies\40 Year Old Virgin 2005 720p\
21:35:25 T:4060 M:2244947968   DEBUG: CMultiPathDirectory::MergeItems, items = 7,  took 16 ms
21:35:25 T:4060 M:2244771840   DEBUG: VIDEO::CVideoInfoScanner::DoScan Skipping dir 'multipath://E%3a%5cMovies%5c/F%3a%5cMovies%5c/M%3a%5cMovies%5c/' due to no change
21:35:25 T:4060 M:2244771840   DEBUG: Hash[movies,multipath://E%3a%5cMovies%5c/F%3a%5cMovies%5c/M%3a%5cMovies%5c/]:DB=[B97E20F28534237AC7A3BAE2BFE69911],Computed=[B97E20F28534237AC7A3BAE2BFE69911]
21:35:25 T:4060 M:2244771840   DEBUG: VIDEO::CVideoInfoScanner::DoScan - Finished dir: multipath://E%3a%5cMovies%5c/F%3a%5cMovies%5c/M%3a%5cMovies%5c/
21:35:25 T:4060 M:2244771840   DEBUG: VIDEO::CVideoInfoScanner::Process - Finished scan
21:35:25 T:4060 M:2244771840  NOTICE: My Videos: Scanning for video info using worker thread, operation took 00:00
21:35:25 T:4060 M:2244771840    INFO: Video scan was stopped or finished ... restoring FindRemoteThumbs
21:35:25 T:4060 M:2244771840   DEBUG: Thread 4060 terminating
21:35:27 T:3164 M:2244816896   DEBUG: SDLKeyboard: scancode: 46, sym: 99, unicode: 67, modifier: 3000
21:35:27 T:3164 M:2244816896   DEBUG: CApplication::OnKey: 61507 pressed, action is 117
21:35:27 T:3164 M:2244812800   DEBUG: CFavourites::Load - no userdata favourites found, skipping
21:35:27 T:3164 M:2244808704    INFO: Loading skin file: DialogContextMenu.xml
21:35:27 T:3164 M:2244804608   DEBUG: Load DialogContextMenu.xml: 0.82ms
21:35:27 T:3164 M:2244804608   DEBUG: Alloc resources: 0.96ms (0.00 ms skin load, 0.12 ms preload)
No help without a full debug log. Do NOT post log snippets!
EDIT: Please try again, tmdb was offline for some time (news on xbmc.org). Should be online and working now.
I sort of have a similar problem. When I press update, nothing happens. If I go to the root folder, the movie is there. When I update the movie information in the root folder, the movie shows up now. Weird.
No log, no way to assist.
sho Wrote:No log, no way to assist.
How to you generate a log? I am having the exact same problem.
see my sig
