Full Version: Subtitles flag
What causes the subtitles flag to appear?
I have several movies that have subtitles and other metadata icons appear except for this one I noticed.
I can play my subtitles fine or disable them so its not like XBMC doesnt view them.
Im using T! v2.0 (full) on XBOX platform on a patched nightly build (22485).
the subtitles should be detected by the media metadata extraction code in xbmc.
note: the code doesn't work for dvd's (.vob files)
I dont have files as vobs for my movies.
I figured the metadata extraction code would pick them up. Ill try a refresh.
My subtitles are *.srt files and labelled exactly like my movies
anyway to make this work?
zeus[x];642634 Wrote:anyway to make this work?
nope, xbmc does not detect external sutitles files.
Too bad, i have to close xbmc all the time to check if a movie have or not subtitles. would be easier is we have a flag with that info.
thanks!
zeus[x];642939 Wrote:Too bad, i have to close xbmc all the time to check if a movie have or not subtitles. would be easier is we have a flag with that info.
thanks!
you can always post a request in the Feature Requests forum.
edit:
there's already a ticket for it:
http://trac.xbmc.org/ticket/8472
