Full Version: Noob needs help updating to 22528
Pages: 1 2
kees667 Wrote:Finally managed it. I needed to force some stuff. I posted details here:
http://forum.xbmc.org/showpost.php?p=416918
Thanks from another noob :-)
i dont work for me =(
root@HTPC:~# wget https://launchpad.net/~team-xbmc-svn/+ar...2_i386.deb
--2009-11-05 20:38:20-- https://launchpad.net/~team-xbmc-svn/+ar...2_i386.deb
Resolving launchpad.net... 91.189.89.222, 91.189.89.223
Connecting to launchpad.net|91.189.89.222|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2009-11-05 20:38:23 ERROR 404: Not Found.
PrimaryMaster Wrote:i dont work for me =(
I am having the same issue. It appears these files were pulled. If that's the case how else can we get to this specific version?
How's that for a first post? Smile
Now those debs are gone, if someone who downloaded them already could put them somewhere that we could get to that would be great.
I would use these two addresses instead if you want to update to alpha 2.
deb http://ppa.launchpad.net/team-xbmc/ppa/ubuntu jaunty main
deb-src http://ppa.launchpad.net/team-xbmc/ppa/ubuntu jaunty main
The one with svn only have alpha 1 in there, thats why you couldn't update and upgrade it to the latest build!
This place has previous SVNs including 22528
http://www.sshcs.com/xbmc/
link for linux deb version is
http://www.sshcs.com/xbmc/?mode=BuildsDo...x&BN=22528
If anyone needs to undo what is done in the above post, you'll need to type the following at the command line :
sudo dpkg -i --refuse-all xbmc-common_9.04.3+svn22528-jaunty2_i386.deb xbmc_9.04.3+svn22528-jaunty2_i38
6.deb xbmc-skin-pm3-hd_9.04.3+svn22528-jaunty2_i386.deb xbmc-web-pm3_9.04.3+svn22528-jaunty2_i386.deb xbmc-eventclients-commo
I needed to do this when I finally decided to update my xbmc - I was seeing errors to the effect that it wasn't able to install anything other than the 22528 versions.
There is a new PPA from today with the latest stable. That should be good enough for most people until the new stable is ready.
It is working fine on e..g ASROCK ION 330
Hi vikjon0,
Could you be a bit more specific please? I am a little confused with all versions and paths to update currently. Would these lines get the version you refer to, and which version is that? (pre alpha2?)
echo deb-src http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ jaunty main >> /etc/apt/sources.list.d/xbmc.org.list
echo deb http://ppa.launchpad.net/xbmc-addons/ppa/ubuntu jaunty main >> /etc/apt/sources.list.d/xbmc.org.list
vikjon0 Wrote:There is a new PPA from today with the latest stable. That should be good enough for most people until the new stable is ready.
kees667 Wrote:Hi vikjon0,
He's referring to this thread : http://forum.xbmc.org/showthread.php?tid=61843
There's an additional PPA for the previous stable version (9.04.1) for hardy, intrepid and jaunty.
Pages: 1 2
