Full Version: Noob needs help updating to 22528
Pages: 1 2
I run mediastream redux skin and I need a newer xbmc build to run it properly. However I also understand I shouldnt understand the latest build as that one is broken now. Build 22528 is recommended as it was the most recent build before it broke (as I understand it)
I installed ubuntu minimal and xbmc (may build) using this script:
http://forum.xbmc.org/showthread.php?tid=55282
The guide has some pointers on upgrading by uncommenting these lines in the script:
#deb http://ppa.launchpad.net/team-xbmc-svn/ppa/ubuntu jaunty main
#deb-src http://ppa.launchpad.net/team-xbmc-svn/ppa/ubuntu jaunty main
and then running:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install xbmc
But will that get me exactly that build 22528 or should I do something else to do that?
I found this link: http://forum.xbmc.org/showpost.php?p=412...tcount=525
But I am as very new to Linux/xbmc and afraid to run it.
hi, i'm also a fellow noob and i can tell you that the last link worked beautifully for me so go on and give it a go. of course after the update,upgrade and install
Chugo Wrote:of course after the update,upgrade and install
Do you mean that after I do
wget https://launchpad.net/~team-xbmc-svn/+archive/ppa/+files/xbmc-skin-pm3-hd_9.04.3+svn22528-jaunty2_i386.deb
wget https://launchpad.net/~team-xbmc-svn/+archive/ppa/+files/xbmc-web-pm3_9.04.3+svn22528-jaunty2_i386.deb
wget https://launchpad.net/~team-xbmc-svn/+archive/ppa/+files/xbmc_9.04.3+svn22528-jaunty2_i386.deb
wget https://launchpad.net/~team-xbmc-svn/+archive/ppa/+files/xbmc-common_9.04.3+svn22528-jaunty2_i386.deb
wget https://launchpad.net/~team-xbmc-svn/+archive/ppa/+files/xbmc-eventclients-common_9.04.3+svn22528-jaunty2_i386.deb
sudo dpkg -i xbmc-common_9.04.3+svn22528-jaunty2_i386.deb xbmc_9.04.3+svn22528-jaunty2_i386.deb xbmc-skin-pm3-hd_9.04.3+svn22528-jaunty2_i386.deb xbmc-web-pm3_9.04.3+svn22528-jaunty2_i386.deb xbmc-eventclients-common_9.04.3+svn22528-jaunty2_i386.deb
I should do this?
sudo apt-get update
Quote:I should do this?
sudo apt-get update
I dont think so.
It should also be possible to do this:
Quote:sudo apt-get install xbmc=[svnVERSION]
But I have not tried it yet.
Would I then try it like this?:
sudo apt-get update
vikjon0 Wrote:I dont think so.
anyone please?
what i did was this
sudo apt-get update
then
wget https://launchpad.net/~team-xbmc-svn/+ar...2_i386.deb
in that order and it worked fine for me
Thanks I'll try tomorrow. Can I just exit XBMC with ctrl-alt-f2 and do this or must I "close" xbmc first somehow?
iam going to test this now....
i think you can
ctrl-alt-f2
pkill xbmc
pkill xorg
and then do this...
Chugo Wrote:what i did was this
sudo apt-get update
then
I did that... did not work for me..
after i reboot i get to the terminal...
what did you have before you did this?
i started with "May 25 2009 (SVN:20654) / Ubuntu Live (9.04.1)"
weird. after sudo apt-get upgrade I get a ot of:
E:unmet dependencies try using -f
I have now ended up with a build compiled in October. Runs fine except for video_ts.ifo files. Guess i am not at 22528 but a slightly newer build.
how did you do?
There was a force option somewhere. System is pretty much crap now so looking for a way to downgrade.
Does anyone know of a fool-proof way to downgrade to a specific ppa build?
Finally managed it. I needed to force some stuff. I posted details here:
http://forum.xbmc.org/showpost.php?p=416918
Pages: 1 2
