2009-10-04, 10:51
When I use the radio feature in XBMC-LiveUSB and play a radio station in Shoutcast, or use the Last.fm is playing songs about 3-4 min then it begins to make problems with buffering. The cache is not set in the GUI in XBMC-LiveUSB (the choice dont exits). I have tested to set it in guisettings.xml but it does not save settings when I changed the audio cache settings. Tried to create a advancedsettings.xml file user repository with adiosettings settings, XBMC seems to use the settings in advancedsettings.xml of them have disappeared in guisettings.xml but there are still problems with buffering when trying to play songs from a radio station. Internet connection should not be a problem. I have a 10/100 Mbps connection to the Internet.
XBMC-Live USB v9.04.1/ASrock ION 330
Grateful for the tips
/Ove
/Ove
