Hi there
for Movies I use the Wall-View, but there are no MediaFlags shown in that Mode (even though enough space there for that).
Any Tip how to include the Flags there?
Greetz Zuphael
well i would do it my self, but i got no clue where to search for that thing in the xml's
in Includes_MediaFlags is something like im looking for:
Furniture_ShowcaseMediaFlagsVars <- but that would need to be "Furniture_WallMediaFlagsVars" what takes no effekt, i think mainly because ther is no counterpart... but where to look for that?
In wich xml are the diffrent views defined?
Zuphael Wrote:Hi there
Greetz Zuphael
Aeon Stark does not support Mediaflags in wall view. If you want mediaflags in wall view I'd recommend you switch to Hitchers Mod of the Auriga skin. It not only adds mediaflags to wall view but also encompases the vast majority of mods into one Huge-Mongo Mod.
http://forum.xbmc.org/showthread.php?tid=54500
well thats is a great tip!
the only bad thing -> When i start xbmc "setup" is selected... can i change that in any way, so it selects tv-shows or movies by default?
