Full Version: Possible Tweak for Recently Added
I think that when you click ^ to get to the recently added TV shows or Movies it would be better if New: and TV Shows: x and Episodes: y weren't the same color as the currently highlighted item. I think they should be grey (until the New: is currently selected) and perhaps the TV Shows: x and Episodes: y could be moved somewhere else, perhaps up top, or more in to the right under the thumb. That way it would help clarify the currently selected item.
(Also the time should be up by the date and in the same font)
Thanks Ronie for all the work on (the only skin that I use) T!
i'll play around with your suggestions and see if i can come up with something i like.
cheers!
ronie Wrote:i'll play around with your suggestions and see if i can come up with something i like.
cheers!
while you at it,do you mind making the blue in recently added window a bit darker? I am not sure is it my 4 eyes that seem to struggle or is it a bit light but I am never sure if I am at the correct movie/Tvshow.
Just a suggestion... Wink
Zeljko
