Full Version: Hyperactive TV
hi,
just a little question, and possibly a suggestion.
is the scaling of the skin in xbmc done in realtime or on load?
if it's done in realtime, my suggestion is to display the menu in pal60 while playing a movie that uses it. the reason; tv's use a long time switching between the two modes (mine at least).
if the scaling is done at loadtime, then i guess this might be hard to do.
spiff
(edited to remove some typos)
yes, i wanna full pal 60 in videos and menus
