2010-08-24, 23:40
2010-08-30, 05:03
I have created a crestron module that registers itself as an event client, allows navigation through the database, displays coverart/thumbnails and displays meta data. It is somewhat rough and I have stopped working on it in as I plan o do a json version (not very much time at the moment for that however). The thumbnail support requires a SVN version Camelot release will not work.
Movies and TV works, Music is incomplete.
Attached are some images. If interested I can send it on.
2010-09-03, 01:58
I have written two new modules: XBMC.usp and XBMC-ES.usp to partially implement the new JSON interface in Crestron programs. Why 2 modules? I found that a lot of simple commands (Up/Down/Left/Right) are not supported by JSON at present so I use the EventServer api for those.
XBMC is a JSON-aware module than returns metadata strings about the currently playing track (Artist/Album/Title etc. ) for Music and Movies. It also implements some of the simpler JSON functions (JumpFwd, JumpBack, Restart/Shutdown/Update library etc.). It doesn't have a browse/search facility at present.
XBMC-ES uses the XBMC event server api to send transport commands and also some built-in commands. It fully implements the api, so adding additional functions is straightforward.
Still to do:
1. Browse/search facility for music, movies etc.
2. TV show metadata
3. Properly queue JSON requests before sending them to xbmc
I included a project module (XBMC.umc) to demonstrate how the 2 modules are linked together.
You can find a zip archive of the modules at http://www.neilcarthy.com/files/XBMC-JSON.zip
Still to do:
2. TV show metadata
2010-09-03, 14:23
Great! Your iPad design is awesome BTW
2010-09-04, 20:05
2010-09-22, 17:02
Thanks for sharing this Neil - great work!!
2010-09-27, 01:22
Glad you like it. Latest version now hosted at: http://code.google.com/p/xbmc-crestron/
The download file now includes a sample SIMPL program and thedroid's touchpanel project.
It's definitely a beta thing so let me know if you find any 'features'!
2010-11-14, 04:50
tzya Wrote:I developed a full Crestron interface.
If you interested I can share it.
i would appreciate it if someone can send me the crestron module, for xbmc or plex
thanks
Patrick
2010-11-14, 06:56
I was just thinking about getting XBMC integrated with Crestron control system in my new house. I even sent the installer a link to json wiki. And ow I see, that someone has come hat way already.
2010-12-04, 20:07
please let me know if crestron module here will also work with plex since architecture is so similar. thanks for any help
2010-12-05, 01:34
HEllo
(Sorry i'm write bad because i'm frenc ;-) )
I have try to test the module but they don't run....
I have tested an manualy connexion => it's ok but not answer when i send a ei command...
Can you help me please ?
Thank you :-)
Thank you :-)
2011-01-06, 22:47
Hello i found my mistake => in XBMC we need to change the web interface for JSONRPC Debug ....
thanks for this module
2011-01-06, 23:38
latest version of the full Crestron module is hosted at http://code.google.com/p/xbmc-crestron/
2011-09-14, 16:15
i can't select the Json rpc as web interface in my xbmc??
