2009-10-11, 01:05
hi
i have beed downloading xbmc svn from 3 days and i can not do a full bootstrap. i got this message al the time:
any ideas ?
PHP Code:
xbmc-build:/usr/src/xbmc# ./bootstrap
autoreconf: Entering directory `.'
autoreconf: configure.in: not using Gettext
autoreconf: running: aclocal --force
autoreconf: configure.in: tracing
autoreconf: configure.in: not using Libtool
autoreconf: running: /usr/bin/autoconf --force
autoreconf: running: /usr/bin/autoheader --force
autoreconf: configure.in: not using Automake
autoreconf: Leaving directory `.'
autoreconf: Entering directory `xbmc/lib/libass'
autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal --force -I shave
autoreconf: configure.ac: tracing
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `shave'.
libtoolize: copying file `shave/libtool.m4'
libtoolize: copying file `shave/ltoptions.m4'
libtoolize: copying file `shave/ltsugar.m4'
libtoolize: copying file `shave/ltversion.m4'
libtoolize: copying file `shave/lt~obsolete.m4'
configure.ac:33: error: possibly undefined macro: AC_DEFINE
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
autoreconf: /usr/bin/autoconf failed with exit status: 1
Please (re)run configure...
any ideas ?
