2009-10-11, 17:41
i just starting to "play" around with XBMC and so far i like it.
I just noticed that i can directly add a ftp server as source and play shows from there. Works fine so far, but the problem is that i cant rename the files on the ftp server and they dont have a XBMC compatible format.
So for example there is "Anime/Bleach/[DB]_Bleach_239_[134CBC70].avi" file, now XBMC will recognize Bleach correctly or i can set a manual title. But even with absolute episode ordering for the tvdb scraper i would have to change it to "s01e239", if i understand this correctly. Since i cant change the filename is there a way to "trick" XBMC to somehow recognize the "..Bleach_239.." episode correctly or does some kind of edit episode title or script exists to aid me here?
So far in the past i used some special ftp tool to check the ftp folders for new files and download them, than i had to hash those via anidb and auto rename the files to a XBMC compatible format so they are listed correctly.
Now if i see it correctly i could directly add my ongoing shows on the ftp server to XBMC and the get file changes/updates automatically, i also dont have to download those shows anymore. But i simply cant change the name on the server, since the server dont belong to me.
any ideas?
Thx Andy
PS: Btw is there a way that XBMC will auto scan all my sources if file changes happens in the background while XBMC runs? For example if a ftp download is complete and the file gets moved into a XBMC source folder? I mean without manually restart XBMC or rescan option?
any ideas?
Thx Andy
