2009-10-14, 17:36
2009-10-14, 17:43
fdrzrich Wrote:The 'library' or 'files' option isn't showing on the 'side' menu in the few skins I tested (Transparancy and Rapier). It is enabled in the settings menu. I'm at work now so I can't get a debug log just yet....
AlphaDog Wrote:Same issue here, but I have the debug log
http://pastebin.com/f5fa46ce7
There is a lot of
DEBUG: Error: Requested setting (videolibrary.enabled) was not found. It must be case-sensitive
here's an update to fix the missing 'library' button in the side menu for Transparency!:
http://forum.xbmc.org/showthread.php?tid=59680
2009-10-14, 18:56
theuni Wrote:I think this is just a case of the svn ppa hitting a rocky spot in svn. Things are fine now, the next PPA revision should resolve the issue.
TheUni
Just so I don't jump the gun and rollback just in time to roll forward again, is it 23965 that should be working?
2009-10-14, 21:15
A search on trac will reveal it was fixed in 23639.
Cheers,
Jonathan
Cheers,
Jonathan
2009-10-14, 21:17
DeFiNL Wrote:1. Go into synaptic and uninstall the latest xbmc svn packages
2. close synaptic when that is done
3. Then go to directory : /etc/var/packages/apt
4. Install the older svn packages manually (install dependencies first!)
This should get you up and running again... i had to go through the same process after updating to the latest svn yesterday...
I'm running Jaunty so no Synaptic, i guess i can use APT but i never upgraded from 23588 so that package doesn't exist in /etc/var/packages/apt (dont even have that path).
I found the .deb packages in /var/cache/apt/archives but no 23588 like i tought...
Bit of a Linux noob here so some help downgrading with Jaunty would be great!
2009-10-14, 21:18
jmarshall Wrote:A search on trac will reveal it was fixed in 23639.
Cheers,
Jonathan
That's great news, when will it be in the SVN repository ya think?
2009-10-14, 23:03
is it solved in this revision:
9.04.3+svn23695-jaunty1
thanks
thanks
2009-10-15, 00:25
Is 23695 > 23639?
2009-10-15, 01:48
no its bigger. why you are saying that?
what do you mean with:
2009-10-15, 01:53
So anything after that revision will work just fine.
2009-10-15, 02:02
the problem is in the version svn23672!
you are saying that it was solved in version 23639!
so the version 23672 came with the same bug so the problem wan´t solved!
2009-10-15, 04:06
Sounds like you are doing something wrong then.
2009-10-15, 05:07
well i just updatedto the latest svn and everything seems to be back to normal including the library problem, you should give the update a try, i also deleted my advancedsettings.xml file before updating
2009-10-15, 10:11
Library is back up with 9.04.3+svn23725-jaunty1. However, the scrapers are not working for me anymore, and the digital audio out settings have been messed up.
2009-10-15, 10:14
Audio is a known issue. What's wrong with the scrapers?
