2009-10-14, 12:29
Sorry mistake in Thread title it should read 23626 !!!
Hi All,
Just upgraded to xbmc-9.04.3+svn23626-jaunty1 and having strange issue in full screen mode with the mouse pointer. I have done a search in the forums and in google and can't see any reports...
system: Ubuntu Jaunty 9.04 all updated to 14/10/2009 (i386)
XBMC: xbmc-9.04.3+svn23626-jaunty1 via PPA
Skin: Default PM3 (ie. I haven't changed anything).
Touchscreen driver: eagalax (also tried evotouch and same results) via USB
Xorg: 1.6 (no physical mouse attached)
Problem:
I was previously running SVN 22278 and all was fine (I had problems with the Library so I thought I would upgrade, Library was always disabled and had no scan option in context menu for music).
After upgrading to 23626 when I run full screen (xbmc -fs) the home screen loads fine and fits the screen fine at 1152x864 60 Hz (like X windows is configured for) but the mouse behaves incorrectly (I say mouse, but I mean the mouse pointer via touchscreen). The only way I can describe it is it ias if the mouse canvas is a lot larger than the screen, as in the top left corner I can see the mouse, but a 1 cm drag down and it speeds off downwards and off the screen. Same with left to right, one small movement and it shoots off the righ hand side of the screen.
I have no problem in window mode, only full screen. X org works fine in same resolution. Tried the video calibration in XBMC and I can see both corners in the correct area of the screen. I have tried changing the resolution in xbmc... same result.
I picked an older SVN to try and the same issue exists in 23164, so I am now back on 22278 and all is well again (except I have the library issue back).
Any ideas ?? I have had a look in the log file, and I see no obvious errors...
Thanks in advance for any help...
A.
Hi All,
Problem:
A.
