Full Version: How to set opensubtitles script path (hidden folder)
First, thanks for a great skin!
I have a problem which is probably simple to solve: how do I set the path to the opensubtitles_osd script when the folder is hidden? The path is C:\Users\MyUserName\AppData\Roaming\XBMC\scripts\OpenSubtitles_OSD, but AppData is a hidden folder and is not shown when navigating folders in XBMC. I can't find where to enter the path manually either...
Thanks in advance!
settings > appearance > view options > show hidden files and directories
Thanks, that solved it! Smile
