Full Version: XBMC live and torrents in background
Hello!
I want to install XBMC Live, but I was wondering if it is possible to have for example qBittorrent running in the background?
I know I can do this if I install XBMC packages after installing Ubuntu, but I do not know how the Live version affect this..
Also I wonder if it is hard to install the nVidia ION drivers for the Asrock Nettop 330 if I use the Live version.. Probably the same, just asking to be sure Smile
THanks
Hi!
I'm using the Clutch Web Torrent with XBMC Live.
To install run "sudo aptitude install clutch" and configure the file /etc/transmission-daemon/settings.json
Nothing better than torrentflux for torrents and sabnzbd for nzb.
Everything runs in the background and all web administered.
