i purchased a remote which should be plug n play for media centre,however i plan on using it with xbmc so i need to configure it, my problem is i can not change what the buttons do it in even ghost as my pc doesnt pic it up as a remote but as i keyboard i think. would i be able to use a wmc driver for it do you rekon? this is the remote i have
http://cgi.ebay.co.uk/PC-Remote-Cont...item2c51353c36
If the remote is being picked up as a keyboard then just remap the keyboard.xml to the keys that your remote is set to.
Say, for instance, you have a button mapped to <K> that you'd like to be the play button. Just map <K> to the play function in keyboard.xml and your remote should work.
thank you , i think thats going to be the best way forward, i need to google a way to find out what keyboard function each button is and then change it to suit xbmc not going to be easy but will have a google unless anyone know how?
look in XBMC's wiki
It has all the player functions and what they are mapped to in there.
