Vincent81 Wrote:Hello,
For access to XBMC on another computer, it is better to go through the XBMC HTTP server by filling the fields IP, login, password in XBNE.
I don't understand why you can not enter the network paths in XBNE. I also W7 with several networked PC at home and it works very well?
Try with "debug" mode and look file "debug.log" in XBNE directory.
I have gone through the HTTP server to load my data. However if I attempt to edit a movie it opens a dialog asking for the path to the NFO file for some reason. Am I editing the movie incorrectly?
How do you access your network shares? I can access them via a mapped drive letter or via UNC naming normally. However using your tool none of the dialogs allow me to access via UNC nor do I see the mapped drives. the mapped drivers are mapped at startup by hand and not mapped permanently if that makes a difference. I will see what I can do about entering debug mode but at this time it's not throwing me any errors..
He asks the question where to put the nfo, because it does not find movie. Choose any directory.
Normally you can use the mapped drive or UNC path.
Tell me please, your program supports Unicode. I ask because video files with a Russian name appear in the program as
?? and accordingly Scraper nothing on such a name is not found.
have you tested to change alphabet used, in Options ?
New version 9.2.2.0
-some corrections.
-MySQL compatible for XBMC SVN.
If you want to test MySQL :
Options> Media Center -> XBMC
Give it the path of standard DataBase (for image cache) and check "Use MySQL" fill Host, User and PassWord.
I forgot to copy these two files in path: Windows/System32/ made manually :
libmysql.dll
mySQL4WD.dll
CAUTION: As XBMC/MySQL, XBNE/MySQL does not accept local disks, change to network disk.
Enjoy.
Hello,
Is there a way to sort by added date or file date ?
this will made easy to change movie entry in the db.
And i don't find how to remove an fanart... because sometime XBMC don't download the good fan art ex: i have toy story fan art on a thriller movie...
And is it possible to add an parameter for the time format of the film ex: i get 2h 8mn by xbne but i prefer to have 2h 08mn
Hello,
By clicking on "Recent" in upper left in the list of movies, XBNE sort movies by No entry in the database.
To delete fanart or thumb: backspace key on fanart or thumb table.
For date format, I'd add the option on future releases.
Hi I hope this helps,
Erreur ?la ligne 3 du traitement Proc?ure globale Verif_Base.
Vous avez appel?la fonction HCr?tionSiInexistant.
Impossible de cr?r le fichier <C:\Program Files\xbne\R?ertoires.ndx>.
Le fichier n'a ??trouv?ni sur disque, ni dans les biblioth?ues (.WDL) ou les composants (.WDK) charg?.
Détail de l'erreur système :
The filename, directory name, or volume label syntax is incorrect.
(123)
----- Informations techniques -----
Projet : nfo_xbm
Appel WL :
Traitement de 'Proc?ure globale Verif_Base' (Procedures globales de nfo_xbm.Verif_Base), ligne 3, thread 0
Fonction 'HCr?tionSiInexistant', syntaxe 1
Que s'est-il passé ?
Code erreur : 70302
Niveau : erreur fatale (EL_FATAL)
Code erreur WD55 : 302
Code d'erreur syst?e : 123
Message d'erreur système :
Dump de l'erreur du module 'WD150HF.DLL' (15.00Dj).
Informations de débogage :
##(IXStream)-Handle=<FFFFFFFF>##
Fonction (7,28)
Informations supplémentaires :
EIT_SRCFILE : <C:\Program Files\xbne\R?ertoires.ndx>
EIT_LOGICALTABLENAME : <Répertoires>
EIT_PILEWL :
Procédure globale Verif_Base (Procedures globales de nfo_xbm.Verif_Base), ligne 3
Initialisation de FenetrePrincipale (FenetrePrincipale), ligne 7
EIT_DATEHEURE : 19/06/2010 09:37:57
Assistance
Using VirtualBox Windows XP..
Thanks..
thanks for your answer i'm very stupid i never see the recent button
I don't explain me correctly i wan't to set a fanart to none ( no picture )
See you. Good week end.
Hopelessone
A problem of accent I think, the file that has a problem is "répertoire.fic"
nicolyon
For erase fanart: erase all fanart in fanart table, and erase cache images of XBMC or load a image from disk.
I installed the French Language uninstalled the program/reinstalled and same problem...
It appears the file C:\Program Files\xbne\R?ertoires.ndx is not there.?
Uploaded with
ImageShack.us
FIXED !!
It appears i didnt set the default language to French for installs..
Uploaded with
ImageShack.us
Working.....NOW to explore..!!
OK, thank for the tip ;-)
I would change the filenames with accents on the next versions...
New version 9.2.2.2
-Correction for MySQL server (only "LocalHost / root / xbmc" worked on previous versions
-Rename "r
épertoire.fic" > "r
epertoire.fic"
Is there any plans to add "Audio Music" or only just for movies?
Thanks...its very good "Tre-Bien"
