(2013-01-19, 01:31)johho Wrote: [ -> ]ok thx. Is there another programm to do similar edit directly the XBMC Database for TV Shows and Music?
simply look at this same forum: you can use mediaelch/mediacompanion/ember/therenamer
(2013-01-22, 13:16)MindGuerrillas Wrote: [ -> ]I've just switched to Frodo and XBNE no longer seems to be storing the Date Added correctly. Everything was fine before on Eden.
When I sort my movie list by "Date Added" my latest movies appear at the bottom of the list instead of the top. This seems to be due to the movies not having a "date added" value stored at all. It's just blank.
Could you please take a look at this for me.
OK, corections in the next version in a few days...
(2013-01-22, 23:45)Vincent81 Wrote: [ -> ]OK, corections in the next version in a few days...
That's great, thank you
New version 17.1
- Blue theme
- Correction :
DateAdded
Extra Images
- Added :
Extra Fanart
Vincent81, It's still not populating the files.dateAdded field. Could you take another look at it please?
vincent
thanks for the new version. The artwork problem is only half solved. After updating library with new infos the discart and logo are still there but poster and fanart will be gone.
Could you please check this, thanks
(2013-01-25, 16:58)MindGuerrillas Wrote: [ -> ]Vincent81, It's still not populating the files.dateAdded field. Could you take another look at it please?
Reload DataBase in Option.
Vincent81,
I reload the database each time but it's definitely still not storing a value in files.dateAdded.
Try it yourself, add a new movie to the database then go into XBMC (Frodo RC3) and sort by date added. The new movie will be at the bottom of the list with no date alongside it.
To further confirm it, look in the database itself and look at the files table. There's no dateAdded value being added.
OK, do the new movies added with XBNE (V17.1) have an OK files.dateadded ?
The old version (< V17) didn't fill the files.DateAdded.
All movies added with old version of XBNE have the files.dateAdded empty.
Vincent81
No. That's the problem. The new version, 17.1, is still not filling in this field.
Can you send me a xbne.log. Activate debug in option, add new movie, save and send me xbne.log.
OK, here is the log file
http://pastebin.com/DJSDiKvn
You can see the following line in the log file
NOTICE: Requéte SQL:insert into files (idFile,idPath,strFileName) values(NULL, 2, "Common People.mov")
As you can see the dateAdded field is not included in the INSERT statement.
Can you please amend it so as to include it.
Thank you
New version 17.2
DateAdded corrected.
vincent
could you say something to the fanart and poster problem ? Are you working on this ?
Eisi
normally management of images with Frodo is good.
can you check and see the file xbne.log if does not work. (enable "debug mode" in the options)
