2013-02-04, 08:17
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
2013-02-04, 18:51
(2013-02-04, 08:17)Vincent81 Wrote: [ -> ]It also works with eden of course
I'm sure it does. I just can't seem to get it to work.
2013-02-06, 04:40
I have just come across a problem when revising my movie 'sets' using XBNE.
Frodo has put the 'Star Trek' Movies into 2 seperate sets - "Star Trek - The Orignal Collection" and "Star Trek - The Next Generation Collection"
I want all Star Trek Movies in one Collection (namely "Star Trek Collection"), and used XBNE to change the sets per movie - XBNE shows the correct data
Once I finished I then checked Frodo and, to my disbelief, the sets had not changed. I even checked the NFO's for the movies and they still has the original sets listed, not my revision.
There are a few other movies i have added to sets, and they also have not changed when checking Frodo.
I am pretty sure the issue is not with XBNE but Frodo - any ideas as to fixing the issue, as it is driving me batty
Cheers[/align]
Cheers[/align]
2013-02-06, 08:16
have you enable the option "save in the nfo" in the options.
2013-02-07, 12:14
I can't remember seeing that option during installation, or in the 'options" or "Maintenance" screens.
Am I looking in the right screen ?
Also, may I request once field to be added to the "export" results (excel, word etc.,) ?
I'd like the "Sets" included in the export results, as i am currently adding them manually
2013-02-07, 20:04
2013-02-08, 15:57
hi guys,
Any idea what causes this error? Already tried re-installing xbne but the error still persist.
_____________________________________________________________________________________________
Erreur à la ligne 1 du traitement Clic sur BTN_Repertoires.
Vous avez appelé la fonction Ouvre.
Impossible d'ouvrir la fenêtre <Table_des_R�pertoires> pour la raison suivante :
> L'objet Table_des_R�pertoires n'a pas été trouvé.
----- Informations techniques -----
Projet : nfo_xbm
Appel WL :
Traitement de 'Clic sur BTN_Repertoires' (FenetrePrincipale.BTN_Repertoires), ligne 1, thread 0
Fonction 'Ouvre', syntaxe 0
Que s'est-il passé ?
Code erreur : 10019
Niveau : erreur fatale (EL_FATAL)
Dump de l'erreur du module 'wd180obj.dll' ().
Identifiant des informations détaillées (.err) : 10019
Informations de débogage :
Chargement de la partie execution d'un objet
Nom physique : Table_des_R�pertoires
Type cherche : 2
Fonction (1,1)
Informations supplémentaires :
EIT_PILEWL :
Clic sur BTN_Repertoires (FenetrePrincipale.BTN_Repertoires), ligne 1
EIT_DATEHEURE : 08/02/2013 21:31:33
Assistance
Projet : nfo_xbm
Appel WL :
Code erreur : 10019
Type cherche : 2
Fonction (1,1)
EIT_PILEWL :
Assistance
2013-02-11, 16:33
New version 17.4
- Sets pictures corrections.
2013-02-12, 19:51
help please
2013-02-12, 23:10
Normaly corrected with 17.4...
2013-02-13, 10:10
Hi Vincent!
Thanks for your great program!!....Amazing effort and amazing support.
I do have a problem with FRODO, movie set. After reading lots of forum messages, the problems seems to be related to a set of blank and spare >set< entries. ( http://forum.xbmc.org/showthread.php?tid...light=xbne )
Is there a way that xbne could check and delete blank set entries? Doing manual editing takes a long time.
Also, should :Group movies in sets: be on or off in XBMC? (If off, how can I undo the entries it created when selecting on)?
Thanks and God bless
Alfred
Alfred
2013-02-13, 10:48
Hi Vincent!
Alfred (sorry double post)
2013-02-13, 21:24
OK, i see that for the next version...Tomorow.
2013-02-14, 18:23
New version 17.6
- Set Correction
- ImdbScraper Correction
- Others....
- Set Correction
- Others....
2013-02-15, 01:53
Hi Vincent, a couple of things.
Firstly, proxy: Does XBNE have support for using a proxy? I've got XBMC (Frodo) running at home, and have configured my router so that I can connect to the XBMC webserver remotely (from work). However, XBNE gives an error when it attempts to connect to the webserver remotely. We have a proxy at work, do I need to somehow configure XBNE to use it?
Second, download: Do you have a site where we can download the latest versions?
Thirdly, web server: Which webserver in XBMC should I be using? I note that Frodo no longer uses the webserver from 11.0.. I think it was called XWMM.
