djselbeck Wrote:Hello,
I can ensure you that it is not a HDCP issue because there is no HDCP support on linux at the moment.
greets
Sorry, but HDCP is in the HDMI chip hardware and is OS independent. DVI-D ports of graphics cards also has it and it is at the graphics card level, handled at layers and in places the OS never even "sees".
However, OS resets, and power resets, etc., can cause 'downstream' devices to 'lose' their HDCP handshake with the source device. In some cases, both devices will fail to 'hook up' (or re-hook up)and leave the system with only a handful of low resolution array choices.
One should always check the discussion forums of the hardware makers that made their motherboard (for integrated graphics)and graphics card, etc.
My Revo with a GPU next to the CPU does blu ray over a USB drive and decodes it and pumps it back out at full resolution and sound without a glitch. I upgraded it to 4GB RAM and a 7200rpm HD, which *does* make a difference.
My other HTPC is a Zotac ITX H55 with an i5 670(?) that has integrated Intel graphics on the cpu.
Both of these hook up at full 1080p resolution. Both also drop out after certain user actions as well. Both recover when I cycle the downstream device, be it the A/V Receiver or the TV itself.
This comes from slight mismatches in "compliance" by different makers of consumer electronic devices that are capable of displaying high resolution protected intellectual property. This can cause an accepted connection to be dropped, or even refused, or get "locked down" to a lower resolution.
The idea was to keep folks from trying to swipe hi res signals right out of the connecting cables. Little did they know we just "rip" it right out of the media itself, and nobody opens up digital HDMI cables trying to grab signals, nor would they had they not done all this stupid HDCP crap.
But it DOES indeed exist, and IS almost always the problem with ANY display resolution that qualifies as HD, which is 720 and up. Not because you are watching protected media, but because you might, and you might want to hack your cable while you are doing it.
It has to have been the dumbest move they ever made, since it costs hardware makers more to implement, and we pay via higher product prices, because they pass it on to us.
It has nothing to do with Linux. It is, by law, not accessible to the user.
http://en.wikipedia.org/wiki/High-bandwi...Protection
