Full Version: nfo structure
Hi Ronie, what is the best structure of an nfo file to get the best from your skins flags
im using an xbox
hope this makes sense
John
i use ember media manager for movies and media info plus for tv shows.
both media managers produce decent .nfo files.
if you're interested in the structure of xbmc compliant .nfo files,
i suggest reading the wiki: http://wiki.xbmc.org/?title=Import_-_Export_Library
I use EMM also and for some reason it doesn't seem to pick up the tags. I got it to partially work once, but no luck since and I'm not even really sure why it worked in the first place.
