Full Version: Error compiling SVN23819
Hello folks,
I'm trying to compile xbmc trunk SVN23819 ,but I have some problem with libtool.
Here it is the log:
make[3]: Entering directory `/home/andrea/sources/xbmc/xbmc/lib/libid3tag/libid3tag'
make[4]: Entering directory `/home/andrea/sources/xbmc/xbmc/lib/libid3tag/libid3tag'
/bin/sh ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.     -Wall -O3 -fomit-frame-pointer -MT version.lo -MD -MP -MF .deps/version.Tpo -c -o version.lo version.c
./libtool: line 467: CDPATH: command not found
./libtool: line 1145: func_opt_split: command not found
libtool: Version mismatch error.  This is libtool 2.2.6 Debian-2.2.6a-4, but the
libtool: definition of this LT_INIT comes from an older release.
libtool: You should recreate aclocal.m4 with macros from libtool 2.2.6 Debian-2.2.6a-4
libtool: and run autoconf again.
make[4]: *** [version.lo] Error 63
make[4]: Leaving directory `/home/andrea/sources/xbmc/xbmc/lib/libid3tag/libid3tag'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/andrea/sources/xbmc/xbmc/lib/libid3tag/libid3tag'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/andrea/sources/xbmc/xbmc/lib/libid3tag/libid3tag'
make[1]: *** [libid3tag/.libs/libid3tag.so] Error 2
make[1]: Leaving directory `/home/andrea/sources/xbmc/xbmc/lib/libid3tag'
make: *** [libid3tag] Error 2
[email protected]:/home/andrea/sources/xbmc>
I'm using Slackware 13 x86.
I've tried to delete aclocal.m4 in libid3tag directory,but without success.
Should I upgrade libtool?I have installed 1.5.26 version atm.
Could you give me some help please?
