Full Version: " bugs
Hello there ...
I like ur work and ur endeavor on XBMC.
I decidee to write u about error (i think it is) witch I found in last
few SVN builds (23718, 23756, 23799 23807).
When i start XBMC and when i use iMON remote or arrow keys i cant move true menus as long as i move cursor on XBMC window.
Same happened when i use keyboard arrows. I cant move true menus till
i don't move mouse on XBMC window. It happends only in dual monitor view, it
seems that pointer/cursor is not in focus of xbmc, it act like it is
on first monitor, and coz that u cant move with arrow keys thrue menus
It seems that pointer is not in focus on first menu place, I hope u
understud me what I wanted to say ...
Another bug witch I found is that visualizations does not work.
Srry for my bad english Sad
Regards Ziiky !!!
This only happend in Transparency skin ...
Zrino Wrote:I decidee to write u about error (i think it is) witch I found in last
the Home Menu should always have the focus when you enter the Home screen.
not sure why it isn't working for you, but if the mouse focus is on the other monitor, i don't know if there's anything i can do. it might be an xbmc bug?
i don't have a dual monitor setup, so i can't test myself.
maybe other users can confirm / shed some light on this ?
Zrino Wrote:Another bug witch I found is that visualizations does not work.
make sure you disable Settings > Skin Settings > General > Show fanart instead of visialization
and of course select a visualization in Settings > Music > General > Visualization
