Full Version: Movie library and two-cd-movies?
I did some searching but couldn't find this question asked before (which seems strange as it must be a common problem?).
I have a movie split in two CDs. The first CD gets scanned correctly into the XBMC movie library, but the second is shown as a duplicate named "Cdd" (probably the closest match to CD2).
Can XBMC handle two-cd-movies somehow?
Thanks in advance!
XBMC handles 2 CD movies just fine. What are the files named?
movie.cd1.avi
movie.cd1.avi
or
movie-CD1.avi
movie-CD2.avi
Should work. Check if you have stacking turned on. It should be default on for library use.
They are in subfolders and RARed, for example:
E:\Movies\Some.Movie\CD1\moviecd1.r00
E:\Movies\Some.Movie\CD1\moviecd1.r01
E:\Movies\Some.Movie\CD2\moviecd2.r00
E:\Movies\Some.Movie\CD2\moviecd2.r01
Perhaps the problem is the RAR archives?
Thanks for helping out!
The two parts have to be in the same directory.
When extracted and placed in the same folder it works, thanks for the help. I guess this "issue" isn't really worth fixing, two-cd-movies is probably something belonging to the past anyway =)
