2009-10-26, 14:34
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: lun oct 26 09:17:53 ART 2009
XBMC Options:
Arch: x86_64
Kernel: Linux 2.6.30.9-90.fc11.x86_64 #1 SMP Sat Oct 17 11:25:35 EDT 2009
Release: lsb_release not available
############## END SYSTEM INFO ##############
############### STACK TRACE #################
[?1034hCore was generated by `/usr/share/xbmc/xbmc.bin'.
Program terminated with signal 6, Aborted.
#0 0x00000030db0332f5 in raise () from /lib64/libc.so.6
Thread 1 (Thread 11007):
#1 0x00000030db034b20 in abort () from /lib64/libc.so.6
#2 0x00000030e1c29da5 in ?? () from /lib64/libdbus-1.so.3
#3 0x00000030e1c25c8a in ?? () from /lib64/libdbus-1.so.3
#4 0x00000030e1c1aa39 in dbus_message_new_method_call ()
#5 0x00000000005da0a5 in CDBusMessage::CDBusMessage(char const*, char const*, char const*, char const*) ()
#6 0x00000000005d9344 in CDBusUtil::GetVariant(char const*, char const*, char const*, char const*) ()
#7 0x00000000005d94d7 in CDBusUtil::GetBoolean(char const*, char const*, char const*, char const*) ()
#8 0x00000000005e49d7 in CDeviceKitDiskDevice::Update() ()
#9 0x00000000005e4bab in CDeviceKitDiskDevice::CDeviceKitDiskDevice(char const*) ()
#10 0x00000000005e50af in CDeviceKitDisksProvider:eviceAdded(char const*) ()
#11 0x00000000005e532c in CDeviceKitDisksProvider::Initialize() ()
#12 0x000000000068b684 in CApplication::Create(void*) ()
#13 0x00000000008999bb in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
09:17:53 T:139817189296368 M:1758076928 NOTICE: -----------------------------------------------------------------------
09:17:53 T:139817189296368 M:1758076928 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Oct 20 2009 (SVN:23866M)
09:17:53 T:139817189296368 M:1758076928 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
09:17:53 T:139817189296368 M:1758076928 NOTICE: special://masterprofile/ is mapped to: /home/germanp/.xbmc/userdata
09:17:53 T:139817189296368 M:1758076928 NOTICE: special://home/ is mapped to: /home/germanp/.xbmc
09:17:53 T:139817189296368 M:1758076928 NOTICE: special://temp/ is mapped to: /home/germanp/.xbmc/temp
09:17:53 T:139817189296368 M:1758076928 NOTICE: The executable running is: /usr/share/xbmc/xbmc.bin
09:17:53 T:139817189296368 M:1758076928 NOTICE: Log File is located: /home/germanp/.xbmc/temp/xbmc.log
09:17:53 T:139817189296368 M:1757646848 NOTICE: Setup SDL
09:17:53 T:139817189296368 M:1756958720 INFO: Available videomodes (xrandr):
09:17:53 T:139817189296368 M:1756958720 INFO: Number of connected outputs: 1
09:17:53 T:139817189296368 M:1756958720 INFO: Output 'default' has 21 modes
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x143 Name:1440x900 Refresh:60,000000 Width:1440 Height:900
09:17:53 T:139817189296368 M:1756958720 INFO: Pixel Ratio: 1,000000
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x144 Name:1440x900 Refresh:75,000000 Width:1440 Height:900
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x145 Name:1152x864 Refresh:75,000000 Width:1152 Height:864
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x146 Name:1024x768 Refresh:75,000000 Width:1024 Height:768
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x147 Name:1024x768 Refresh:70,000000 Width:1024 Height:768
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x148 Name:1024x768 Refresh:60,000000 Width:1024 Height:768
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x149 Name:832x624 Refresh:75,000000 Width:832 Height:624
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x14a Name:800x600 Refresh:75,000000 Width:800 Height:600
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x14b Name:800x600 Refresh:72,000000 Width:800 Height:600
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x14c Name:800x600 Refresh:60,000000 Width:800 Height:600
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x14d Name:800x600 Refresh:56,000000 Width:800 Height:600
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x14e Name:700x525 Refresh:75,000000 Width:700 Height:525
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x14f Name:700x525 Refresh:60,000000 Width:700 Height:525
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x150 Name:640x480 Refresh:75,000000 Width:640 Height:480
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x151 Name:640x480 Refresh:73,000000 Width:640 Height:480
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x152 Name:640x480 Refresh:60,000000 Width:640 Height:480
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x153 Name:512x384 Refresh:70,000000 Width:512 Height:384
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x154 Name:512x384 Refresh:60,000000 Width:512 Height:384
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x155 Name:400x300 Refresh:72,000000 Width:400 Height:300
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x156 Name:320x240 Refresh:73,000000 Width:320 Height:240
09:17:53 T:139817189296368 M:1756958720 INFO: ID:0x157 Name:320x240 Refresh:60,000000 Width:320 Height:240
09:17:53 T:139817189296368 M:1756700672 DEBUG: CKeyboardStat::Initialize - XKb symbols pc_latam_inet(evdev)_srvr_ctrl(terminate_ctrl_alt_bksp)
09:17:53 T:139817189296368 M:1756700672 INFO: LIRC Initialize: connect failed: No existe el fichero o el directorio
09:17:53 T:139817189296368 M:1756700672 DEBUG: Failed to connect to LIRC. Retry in 10s.
09:17:53 T:139817189296368 M:1756700672 DEBUG: DeviceKit.Disks: Querying available devices
09:17:53 T:139817189296368 M:1756700672 DEBUG: DBus: Creating message to org.freedesktop.DeviceKit.Disks on /org/freedesktop/DeviceKit/Disks with interface org.freedesktop.DeviceKit.Disks and method EnumerateDevices
09:17:53 T:139817189296368 M:1756700672 DEBUG: DeviceKit.Disks: DeviceAdded (/org/freedesktop/DeviceKit/Disks/devices/sda1)
09:17:53 T:139817189296368 M:1756700672 DEBUG: DBus: Creating message to org.freedesktop.DeviceKit.Disks on /org/freedesktop/DeviceKit/Disks/devices/sda1 with interface org.freedesktop.DBus.Properties and method Get
09:17:53 T:139817189296368 M:1756700672 DEBUG: DBus: Creating message to org.freedesktop.DeviceKit.Disks on /org/freedesktop/DeviceKit/Disks/devices/sda1 with interface org.freedesktop.DBus.Properties and method GetAll
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
XBMC Options:
Arch: x86_64
