Full Version: AC3 audio, stuttering HD video, SVN r20459
Just upgraded from 9.04.1 to SVN r20459 and have the following observations.
1. AC3 audio now works! Great news. I use both a analog audio connection to my TV and a digital connection to my receiver. With AC3 sound, I hear a clicking noise on the TV. Is it possible to either (1) disable the analog audio output when processing AC3 sound, or (2) convert to stereo output for the analog interface?
2. When playing a movie with AC3 that played well in 9.04.1 (Amadeus, media info below), the video appears to have problems -- a message at start of play that says "Failed to init video filters/scalers. Falling back to ..." and stuttering.
3. During playback the menu button stops play; it used to continue play but go back to the file list menu. Is this change design intent or a bug?
XBCM log at http://filebin.ca/jgrhwj ; media info for Amadeus below.
Niall
*** MediaInfo Mac // Plain text file report
2009-10-27 07:41:29 -0400
Information for File: Amadeus.DirCut.1984.720p.m4v
General / Container Stream # 1
Total Video Streams for this File -> 1
Total Audio Streams for this File -> 2
Video Codecs Used -> AVC
Audio Codecs Used -> AAC LC / AC3
File Format -> MPEG-4
Play Time -> 3h 0mn
Total File Size -> 2.56 GiB
Total Stream BitRate -> 2 030 Kbps
Title (Tag) -> Amadeus - Director's Cut
Encoded with -> HandBrake svn2318 2009041201
Video Stream # 1
Codec (Human Name) -> AVC
Codec (FourCC) -> avc1
Codec Profile -> [email protected]
Frame Width -> 960 pixels
Frame Height -> 400 pixels
Frame Rate -> 23.976 fps
Total Frames -> 259554
Display Aspect Ratio -> 2.405
Scan Type -> Progressive
Colorimetry -> 4:2:0
Codec Settings (Summary) -> 3 Ref Frames
QF (like Gordian Knot) -> 0.133
Codec Settings (CABAC) -> No
Video Stream Length -> 3h 0mn 25s 556ms
Video Stream BitRate -> 1 226 Kbps
Video Stream BitRate Mode -> VBR
Bit Depth -> 24 bits
Video Stream Size -> 1.54 GiB (60%)
Video Encoder -> x264 - core 67
Video Encoder (Settings) -> cabac=0 / ref=3 / deblock=1:0:0 / analyse=0x1:0x131 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=6 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=240 / keyint_min=24 / scenecut=40 / rc=crf / crf=21.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Date of Original Encoding -> UTC 2009-04-12 18:50:43
Audio Stream # 1
Codec -> AAC
Codec (FourCC) -> 40
Audio Stream Length -> 3h 0mn 25s 707ms
Audio Stream BitRate -> 160 Kbps
Audio Stream BitRate Mode -> VBR
Number of Audio Channels -> 2
Audio Channel's Positions -> L R
Sampling Rate -> 48.0 KHz
Bit Depth -> 16 bits
Audio Stream Size -> 206 MiB (8%)
Audio Stream Language -> English
Audio Stream # 2
Codec -> AC-3
Codec (FourCC) -> ac-3
Audio Stream Length -> 3h 0mn 25s 696ms
Audio Stream BitRate -> 640 Kbps
Audio Stream BitRate Mode -> CBR
Number of Audio Channels -> 6
Audio Channel's Positions -> Front: L C R, Surround: L R, LFE
Audio Stream Size -> 826 MiB (32%)
