Full Version: Fedora12Beta - No remote
Hello, I am trying fedora12 beta with xbmc.
Quite everything ok, except for remote (mceusb) which no longer works.
I use lirc, and with Fedora11 all worked out of the box.
Note that remote works as usual in all other applications like mplayer or myth, so I do not think is totally OS related.
I tried same xbmc build I worked on F11, I tried a new build, I tried hansvon rpm (http://hansvon.homelinux.org/fedora/11 and 12) which worked on 11. No remote
Can someone point me to the correct direction to find out what happened?
Thank you
No clue?
marco2bb2 Wrote:Can someone point me to the correct direction to find out what happened?
Thank you
Solved. The problem was in the change of name in lirc socket. In fedora <= 11 it was /dev/lircd , in Fedora 12 it became /var/run/lirc/lircd so XBMC was not able to communicate with it.
As a simple workaround, I made a ln -s /var/run/lirc/lircd /dev/lircd and all is ok now.
