davilla Wrote:Did you reinstall Candelair ?
Yes. I uninstalled Candelair, tried the remote, didn't work, reinstalled Candelair, tried the remote, didn't work. It will work with OSX if I activate the leopard compatibility mode but not if that mode is deactivated.
Thanks in advance for the help.
hey58 Wrote:Yes. I uninstalled Candelair, tried the remote, didn't work, reinstalled Candelair, tried the remote, didn't work. It will work with OSX if I activate the leopard compatibility mode but not if that mode is deactivated.
What's the leopard compatibility mode?
Candelair is _not_ needed on 10.6.2. Just uninstall it (reboot needed). Then launch up xbmc, check if remote works and pastebin xbmc.log if it doesn't.
Apple Remote still doesn't work after I removed Candelair and rebooted. xbmc.log at address below. Sorry if that is a bad pastebin site. My first try
http://pastebin.com/m43593759
hey58 Wrote:Apple Remote still doesn't work after I removed Candelair and rebooted. xbmc.log at address below. Sorry if that is a bad pastebin site. My first try
http://pastebin.org/55625
pastebin is fine, but I don't see anything wrong.
Do you have AppleRemote enabled/set to standard in Settings->System?
Another thing you could check if another helper is already running. Open up a terminal and do
ps aux | grep -i helper
Finally I'd try to manually launch XBMCHelper and see what it says. In terminal do
/Applications/XBMC.app/Contents/Resources/XBMC/tools/osx/XBMCHelper -v
cheers,
mdd
It looks like iTunesHelper is running. How can I stop that?
Macintosh:~ user$ ps aux | grep -i helper
user 278 0.1 0.0 2425520 72 s000 R+ 7:05PM 0:00.00 grep -i helper
user 123 0.0 0.2 2474788 4844 ?? S 4:41PM 0:00.06 /Applications/iTunes.app/Contents/Resources/iTunesHelper.app/Contents/MacOS/iTunesHelper -psn_0_40970
user 246 0.0 0.1 99904 2588 ?? S 7:03PM 0:00.05 /Applications/XBMC.app/Contents/Resources/XBMC/tools/osx/XBMCHelper -x
Macintosh:~ user$
I also tried to manually launch XBMCHelper and here is what happened in terminal. Still doesn't work.
Macintosh:~ user$ /Applications/XBMC.app/Contents/Resources/XBMC/tools/osx/XBMCHelper -v
XBOX360: Registering for notifications.
initializing apple remote
uninitializing apple remote
deleting commands map
udp socket (4) opened
Using key code for OSX 10.5
Registering command 21_
Registering command 35_
Registering command 22_
Registering command 23_
Registering command 29_
Registering command 30_
Registering command 4_
Registering command 3_
Registering command 20_
Registering command 18_
Registering command 18_30_
Registering command 18_21_22_
Registering command 18_21_23_
Registering command 18_21_29_
Registering command 18_21_30_
Registering command 18_21_21_
Registering command 18_29_21_
Registering command 18_29_23_
Registering command 18_29_22_
Registering command 18_29_29_
Registering command 18_29_30_
universal mode off.
exclusive lock failed
hey58 Wrote:It looks like iTunesHelper is running. How can I stop that?
Macintosh:~ user$
Another XBMCHelper or PlexHelper. iTunesHelper is not a concern.
uhm, that helper you're using is quite old (I think it's the Atlantis version).
Sure you're running a current version of XBMC?
MaestroDD Wrote:uhm, that helper you're using is quite old (I think it's the Atlantis version).
NOTICE: Starting XBMC, Platform: Mac OS X. Built on May 26 2009 (SVN:20677)
Not a chance
OK information on this thread is a bit confusing. If I finally take the plunge and install 10.6.2 on my mini will I need candalier or not?
garyi Wrote:ok information on this thread is a bit confusing. If i finally take the plunge and install 10.6.2 on my mini will i need candalier or not?
maestrodd Wrote:[...]candelair is _not_ needed on 10.6.2. [...]
hth
OK I am going to go for it then. I have spooged my library any how so may as well start from scratch.
How do I use a more recent version of XBMCHelper?
Edit: I installed 9.11.Alpha2 and all works. I still have the question about using a different version of XBMCHelper though... Was the version of XBMCHelper that I was using not associated with the version of XBMC that I was using?
hey58 Wrote:[...]
glad it works.
and yes, XBMCHelper version is tied to XBMC.
I can't get my remote to work either. XBMC 9.11 Beta 1 on 10.6.2 on a Core 2 Duo mini.
Candelair uninstalled and rebooted.
Log:
Quote:video-mini:~ frontrow$ /Apps/Multimedia/XBMC.app/Contents/Resources/XBMC/tools/osx/XBMCHelper -v
universal mode off.
Any tips?
PS: I also have Plex on this machine. My remote works with that.
