Hey guys. I hope one you can help me or put me in the right direction... I´d love to customize my Transparency Home Menu to show a "MythTV" Option, that opens a myth://1.2.3.4 path directly. Maybe it would be possible to change an entry that I don´t use anyway, like "Trailers".
I´m using the horizontal Home Menu style...
I really have no clue how to implement this or where to look. Any help on this matter would be greatly appreciated
Thanks ronie, thats exactly what I was looking for. But there is still one question left I could not figure out...
- TV Stuff is loaded via a URL starting with myth://x.y.z.a
- I got a source in Video Files called mythtv
So I created another Button called MythTV in the Menu pointing to VideoFiles,mythtv by using XBMC.ActivateWindow(VideoFiles,mythtv)
This works and i see some other Dirs:
- Guide
- Channels
- etc.
Is there a way to directly jump to Channels? As far as I can say you can only give one argument after VideoFiles, so VideoFiles,mythtv,channels or something like that did not work. Is there a possible solution to this, or do I have to live with that?
Again, Thanks for the help and for your awesome Skin! Instantly became my favorite ^^
ingrimsch Wrote:Thanks ronie, thats exactly what I was looking for. But there is still one question left I could not figure out...
- Guide
- Channels
- etc.
how about XBMC.ActivateWindow(VideoFiles,mythtv/Channels) ?
i'm no mythtv user, so i can't test myself...
No Luck here... I tried various combinations, but Logs indicate the Path cannot be found. Too bad.
But well, at least I got a fancy Button for my Live TV stuff now.
Thanks again for your help ronie!
You can edit the source link to point to a certain folder or you just edit the button link to.
ActivateWindow(VideoFiles,myth://USERNAME
ASSWORD@IP-ADDRESS/channels)
fo0d
Works! Thanks mate, this works. I tried to use a Video source which would not work at all, but the direct link to the channels works like a charm. Much appreciated!
