2009-10-31, 03:15
2009-10-31, 03:15
2009-10-31, 18:08
Bump! is there a way I can convert the scraper to search for my naming conventions?
2009-10-31, 23:28
Assuming they're US airdates (i.e. they correspond to the ones that are actually used on thetvdb.com etc.) then newer versions of XBMC allow scraping by airdate.
Have a hunt around the forums - it may be that you need to muck around a bit with regexps.
Cheers,
Jonathan
Cheers,
Jonathan
2009-11-02, 03:35
Not having much luck... I've been searching all day. Lots of references to regexps.
2012-01-13, 21:57
Just wondering if this issue has ever been solved so that XBMC can scrape BeyondTV-recorded shows.
I'd love to have BTV as my recording backend, and have XBMC as my beautiful front-end, but am not sure the best way to get BTV's recordings into XBMC as automatically as possible.
