Great work! ThX!!!!!
Only 2 notice, if i can
- some films not recognized by scraper but searching on the site, there are.
- It's possible to add characters in the cast section like in other scraper (imdb, tmdb) or is a movieplayer.it limitation?
- The scraper use a google search engine and not it's own movieplayer.it search becaue it's encoded with "base64". There is nothing i can do about that, just hope an xbmc dev write some code to handle the base64 string encoding.
- Check in the scraper settings the "Full cast" option and you'll have the characters (it's a little buggy in this last version but better than nothing
Cheers
hi guys i have a problem with this scraper and the last svn available on repo.i've made a screenshot, this is what i've got when search for a movie....
https://dl-web.dropbox.com/get/Photos/sc...w=3cafd49f
it missed a lot of things, even if the film is listed
in the previous nightly build it works
tnx for the great work...
oppps... I wrote it in italian... anyway..
I start hating movieplayer... I just point out that at the moment the latest plugin for the nightly version (the one in the first page) doesn't download director, writer and year.
Ciao ciao!
stefano85 Wrote:it missed a lot of things, even if the film is listed
I cant see the picture, anyway use always the plugin in the first page overwriting the one present in the xbmc version
Ok I updated again the scraper to match the last site changes, but starting from today i'll update it just for the latest version of xbmc, no more 9.11 support.
The actors scraping now should work well in Fullcast mode too.
Enjoy
... and again i made some small fixes and mods.
20/07/2010 - Small optmizations for better results; slightly mods to plot, tagline and outline; some small fixes for Xbmc Dharma
KoTiX Wrote:... and again i made some small fixes and mods.
as usual... thanx alot!!!
just a consideration: until the ufficial version is still the 9.11 please consider the possibility to keep the plugin updated also for this version
KoTiX Wrote:The actors scraping now should work well in Fullcast mode too.
Enjoy
YOU are the best! THX a lot!
gatto_mannaro Wrote:as usual... thanx alot!!!
Considered and done!
But i cannot test it as i don't have that version anymore, just let me know if there is anything wrong.
Cheers and tnx everybody for the nice comments
Plot is missing...
Please could you fix it?
tetodbs Wrote:Plot is missing...
Which version are you talking about? 9.11 or dharma?
Which skin are you using?
tnx
KoTiX Wrote:Which version are you talking about? 9.11 or dharma?
tnx
Dharma version, skin Aeon65.
Yesterday I added 4 new movies and all data were download but plot is missing:
tnx
Same problem, Dharma, Transparency!
