KoTiX Wrote:Great!!!
CHEERS
hello KoTiX!
just a question... for a while (maybe since its born, I've noticed that just now) movieplayer site has got also a "homevideo" section, where some movies are present, while they are not in "film"
I think it would be great if your scraper looks also in this section when it is searching for infos about movies
thanx alot for everything and best regards
GM
Yep, i know there is the homevideo section, but there aren't a lot of infos to retreive from there:
- the plot (trama)
- the poster, not the movieplayer.it fanart and because there is not the original title either will be hard to get the TMDB fanart too
- the studios
and because the links of the pages are a little different from the "film" ones i didn't find a right way arrange the scraper for that.
Anyway if you guy think that the these 3 things will be better than nothing i'll try to work on it.
BTW please give me some movie title that are only in the homevideo section and i'll see if i can play with them a little.
Ciao
KoTiX Wrote:BTW please give me some movie title that are only in the homevideo section and i'll see if i can play with them a little.
Ciao
hello!!
thank you for your usual quick feedback.
I know, some infos lacks on these pages, but as you wrote... something is better than nothing.
Then I think that it can be used just as an extra search, when in movie section no infos can be retrieved.
Some titles... for instance the 9 dvds of conan il ragazzo del futuro (2007)
ciao!
GM
Hi guys, as gatto mannaro suggested, I tried to make some changes to the scraper to include somehow the homevideo section of the movieplayer.it site.
Before to submit the scraper to the official repository i'd like that somebody try these changes and report me back how they have worked with both Google and MP search engines and what he think of them.
You can find the new version of the scraper here:
http://www.mediafire.com/?ncd3r8w3h1544v6
Go in the scraper settings and enable the "Includi gli homevideo nella ricerca"
Tnx in advance, Cheers
where can i find the tvshow version up to date?
is it different from the mail film version right?
Xbmc will automatically update it for you but if it doesn't you can get it from my git repository (link is in first post).
Cheers.
KoTiX Wrote:Hi guys, as gatto mannaro suggested, I tried to make some changes to the scraper to include somehow the homevideo section of the movieplayer.it site.
if "Includi gli homevideo nella ricerca" is enabled about 95% of scraped files have no plot/outline/tagline.
if i rescrape the same files without "Includi gli homevideo nella ricerca" 100% of file are ok, with at least plot.
gulp Wrote:if "Includi gli homevideo nella ricerca" is enabled about 95% of scraped files have no plot/outline/tagline.
In the homevideos section of the site are missing many details of the movies, the plot should have worked but maybe i did something wrong. I'll recheck that.
Anyway i'd like to know if that option have helped finding some more movies for you or it have just messed the things up?
Would it maybe more usefull a more specific "Homevideos" scraper instead?
KoTiX Wrote:...
it can find some more content...but i think is better to leave this option off, and turn it on just for some difficult to find content.
yesterday i've scraped some movies, but movieplayer scraper, returned only partial information.
Maybe the movieplayer website is changed?
This scraper isn't working anymore
Tnx for reporting it, I'll take a look at it as soon as i can.
Ciao
KoTiX Wrote:Tnx for reporting it, I'll take a look at it as soon as i can.
Ciao
Thanx!! Your scraper is fondamental for italian content
waiting for a fix, ciao!
