Movieplayer has changed again the layout
movieplayer scraper needs an update
09/2012:
I agree. Movieplayer has changed the site's content...Scraper doesn't work correctly anymore, needs update, please
thx guys
Hi gulp,
the scraper needs some review as it's not working anymore.
thanks
ok, when i'll be back from my summer holidays, i'll try to fix it.
I've updated the scraper for Movieplayer.it, submitted to XBMC developers for auto update, usually will be in official repo in some days.
If you want to update it manually, download it from here:
http://goo.gl/Ruy1J
or take it from github.
Bye all!
(2012-09-18, 13:04)gulp Wrote: [ -> ]I've updated the scraper for Movieplayer.it, submitted to XBMC developers for auto update, usually will be in official repo in some days.
If you want to update it manually, download it from here: http://goo.gl/Ruy1J
Bye all!
GRAZIE!!
GRAZIE!
Pure da parte mia
Grazie mille! Thx a lot!!!
ancora problemi comunque su alcuni titoli, se non vengono trovati automaticamente e se fa la ricerca manuale spesso nel popup di scelta titolo appaiono altre info come posizioni perse e così via invece del solo nome del titolo.
Inoltre ad esempio, sempre per i file che non trova automaticamente, se creo un file nfo mi setta il film come rilevato ma senza nessuna info (titolo, aano, attori, nulla).
questo il contenuto di un file nfo
http://www.movieplayer.it/film/ai-confin...iso_13792/
Something don't work today?
All new scan don't show actor, or show only some not protagonist.
Hi
it also seems to have a problem with movie scores... the mymovies scraper correctly populates the scores, while mymovies scraper does not.
Also, there seems to be an issue with the movieplayer tv series scraper, it isn't finding anything for any series (While tvdb is working fine)
it doesn't work anymore...Can't retrieve cast info, hd fanart, imdb rating and complete plot...can you fix it?
thx a lot
d
There is a problem with IMDB scraper,
i've fixed Movieplayer link with IMDB, now seems to work for me,
this is the fixed Movieplayer scraper (hope someone will fix IMDB scraper soon)
http://goo.gl/hSIBc
let me know if is fixed for you too, so i'll submit it to official repo.
