Here is Gmail Checker Script
http://opensubtitles-osd.googlecode.com/...r_v0.5.zip
- v 0.5
- Check for new messages only
- Display Sender, Subject, Time and Summary of the message
- Set recheck interval
------ Instalation ---------
- Copy Script to your scripts folder.
- Set username and password in Script Settings.
----- Notes ----
- Only tested on ATV and OSX, if you test on other platforms please post your results.
Cheers,
Zeljko
Oh exactly what I was looking for! Thanks! It works flawlessly on my win xmbc, but it would be nice to be able to open each individual message and see the content on several rows instead of one.
Also, a global notification when a message is received would be awesome.
fillidill Wrote:Oh exactly what I was looking for! Thanks! It works flawlessly on my win XBMC, but it would be nice to be able to open each individual message and see the content on several rows instead of one.
Seeing the entire message is a limitation of Gmail and atom, we only get the "summary" of the message.
Global notification can be done but that means that you will need to run the script at boot, and have it check every so often, and when new mail arrives it will notify you.
I will see what I can do.
Zeljko
Nice work Zeljko, I'll try it later on Xbox.
Dan Dare Wrote:Nice work Zeljko, I'll try it later on Xbox.
Thanks Dan,
Let me know if it is worth uploading on XBMC Zone
Amet Wrote:Thanks Dan,
It'd be nice to have in xbmc-addons
I found it a bit hard to get access to main xbmc-addons repository, that's why I started my own repository in the first place... I did suggest a few times that XBMC.org web interface should change and allow people to upload their addons in there (ZIP), pretty much like other websites allow (e.g. XBMCZone.com) and have a main XBMC installer that retrieves the information from the repository in XML format (faster). I find SVN Repo Installer quite slow to go through the 50 addons in the video section for example... I even volunteered to contribute to such a feature, but I guess XBMC Team has that on a lower priority. I understanda though there is an addons-framework in progress (
http://xbmc.org/donj/2009/10/27/xbmc-get...mment-8520).
Hi!
TNX for the script. I will test it on XBOX and will report back.
It would be also nice to have an option, so the script can checks for the emails in the background (while watching movies or listening to the music) and warn you when a new mail arrives (like XinBox warns you with 'you have new mail').
http://rapidshare.de/files/47269573/XinBox_i4.rar.html
Later on POP and SMTP would be also nice or. even exchange support
Cheers
illiac4 Wrote:Hi!
It would be also nice to have an option, so the script can checks for the emails in the background (while watching movies or listening to the music) and warn you when a new mail arrives (like XinBox warns you with 'you have new mail'). http://rapidshare.de/files/47269573/XinBox_i4.rar.html
Cheers
This is just a 0.5 version, wait until I get to 1.5 ...
Hi!
It works on XBOX without any problems
Well the support for more then one gmail account would be nice and also support for gmail domain mail check.
Cheers
it's working just fine on linux too. :-)
i'm sure it's just a personal preference (i'm not a big fan of scrolling text), but i did like your initial idea to display the summary at the bottom slightly better.
To the developer:
For some feature ideas. check out XinBox
http://forum.xbmc.org/showthread.php?tid=27739
Its abit broken now i think, but a cool feature was MiniMode.
Scripts minimizes and checks for new emails at a set time interval.
it notifies user if new email comes in and then you can press a button to launch the script and view the email
Good luck
"error connecting to gmail" on windows 7 x64
logictester Wrote:"error connecting to gmail" on windows 7 x64
Thanks for letting me know but unfortunately I cant do much without the debug log.
Zeljko
