2009-11-01, 13:21
2009-11-01, 13:35
install xbmc-standalone and change session from gnome(or fluxbox) in GDM.
2009-11-01, 15:57
ok, how do i write a session file for gdm ?
2009-11-01, 16:59
Quote:ok, how do i write a session file for gdm ?Well, if you press F10 or click on the option symbol in the gdm login screen you get the option to change session.
2009-11-01, 18:35
ok, but there is nothing conserning xbmc, I compliles xbmc by my self under debian lenny.
2009-11-01, 18:47
Quote:ok, but there is nothing conserning xbmc, I compliles xbmc by my self under debian lenny.Ok, you need to have the xbmc-standalone package. If the problem is that you do not have that or that it is not compatible with the gdm in debian, I have no idea.
2009-11-01, 19:03
If you meant how to maually set it up, I don't know. You can of course download the xbmc-standalone source and see what it does.
2009-11-01, 20:06
voyager_mp Wrote:Hi, I wont to start xbmc from gdm (xbmc users) right now I do it with fluxbox, but there should be a way without...
thx Michel
create a .config/autostart directory
in there create a file xbmc.desktop
[Desktop Entry]
Encoding=UTF-8
Name=XBMC
Comment=Xbox media center
Exec=/usr/bin/xbmc -fs
Terminal=false
Type=Application
Categories=Application;AudioVideo;Player;
StartupNotify=true
2009-11-01, 20:43
@dc2447
That would be an autostart under gnome right ?
What I'm looking for is a way to start xbmc right out of gdm, without any wm, a watchdog script would be even be better.
2009-11-01, 20:55
found a way, thx anyway.
create a file called /usr/share/xsessions/xbmc.desktop
after that you can select xbmc from gdm
[Desktop Entry]
Type=XSession
Exec=xbmc-standalone
TryExec=xbmc-standalone
Name=XBMC
2009-11-01, 22:16
You could edit .xsession in your home folder and put this in there:
exec xbmc --standalone
2009-11-01, 22:42
or
.xinitrc
.xinitrc
