(2013-03-29, 20:36)Zernable Wrote: [ -> ] (2013-03-29, 19:50)rob6962 Wrote: [ -> ]I have the same issue been dealing with for about 1 week now. upgraded to 2.1.0.
running frodo 12.0 with Aeon Nox 4 Skin
http://pastebin.com/xe3VSHbE
Per the debug log you posted, the query is returning 118 TV shows. What web browser are you using?
Firefox.
My movies show up fine just the TV shows are empty
(2013-03-29, 16:25)slash Wrote: [ -> ] (2013-03-29, 16:12)Branphma Wrote: [ -> ]Hey,
i am running frodo 12.0 with Aeon Nox 4 Skin. I have all my movies in the movies library and my tv shows in the matching library. In XWMM the tv section is totally empty. I am using smart playlists, maybe this can cause a problem? But then, i have a smartplaylist for all my movies and another for all my tv shows to exclude the documentaries...
Could you put XBMC in debug mode and access the web interface again then post the log here via pastebin ?
I'll have a look at it.
Hey,
here is my log:
http://pastebin.com/35RFKEKV
I am using Google Chrome, also tried Firefox...makes no difference.
Firstly, thank you very much for this great tool. It's exactly what I was looking for,
One suggestion or feature request - on entering IMDB movie code (like tt123456) allow to read the rest of movie information from IMDB.
The problem is sometimes XBMC can't get the correct entry, while manual search on IMDB web site gives the right one, Picking up the IMDB ID and loading the rest based on it would allow fixing wrong movie info quickly.
(2013-03-30, 10:39)VictorR1961 Wrote: [ -> ]Firstly, thank you very much for this great tool. It's exactly what I was looking for,
A while a go a wrote some code and submitted it to the XBMC team to do exactly what you are requesting. I'll do a follow up.
Movies by Genre is what I usually use. It is greyed .. I assume that development isn't that far yet. If I am missing out on something .. pls let me know.
Does anyone have any ideas when we'll have the ability to create sets manually with this?
When I try and install XWMM v2.09 I get an error message saying "Dependencies not met". What dependencies do I need to install for XWMM?
I turned on debugging and this is from the log file:
20:53:07 T:3008395072 DEBUG: ------ Window Deinit (FileBrowser.xml) ------
20:53:07 T:3008395072 DEBUG: Addon webinterface.XWMM requires xbmc.gui version 3.00 which is not available
20:53:07 T:3008395072 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
20:53:07 T:3008395072 INFO: msg: PICTURE::LoadImage: Unable to open image: /home/htpc/XWMM-209.zip/icon.png Error: (0)
20:53:07 T:3008395072 ERROR: Texture manager unable to load file: /home/htpc/XWMM-209.zip/icon.png
20:53:09 T:2729368384 DEBUG: DoWork - took 125 ms to load special://skin/backgrounds/programs/programs4.jpg
(2013-03-31, 15:05)daniello Wrote: [ -> ]Movies by Genre is what I usually use. It is greyed .. I assume that development isn't that far yet. If I am missing out on something .. pls let me know.
Sorry but this feature has been disabled for now. Because of the changes in the JSON API, we need to do some additional code.
We are working on getting it back :-)
I found the solution and it was to install version 2.10
(2013-04-01, 11:52)gyrex Wrote: [ -> ]When I try and install XWMM v2.09 I get an error message saying "Dependencies not met". What dependencies do I need to install for XWMM?
gyrex considering 2.0.9 is Only for Eden Yes the only solution is to use a Frodo 2.1.0 compatible version.
uNi
I'm on a fresh install of windows, xbmc and all freshly scraped and I can't get TV Shows to work in XWMM either.
they do work in the default though.
Did anyone happen to find a fix for this yet?
For those having an issue with the TV Shows view working... if you use Firefox or Chrome, can you open the error console (Javascript console in Chrome) via the Tools menu and then try loading the TV Show view? Please post any error messages that appear in the console.
When I pull up the console in Chrome, I don't get any errors or warnings after clicking on TV shows ( or clicking anywhere for that matter )
Same here, no error message.
Using Frodo 12.1 and downloaded the last zip from github. Then I tried both FF and IE - I cannot create movie sets to put the movies into. Any idea? Is this already supported?
Thanks,
Oren
