removing the Volumes source removed my whole Library. Isn't that possible? Weird, because I also have the Films source...
Hmm...I don't have a Mac so I can't be very helpfull
Try this:
- make sure you have only the Films source
- use XWMM to rescan that source: right-click menu then scan for new content or from the XBMC interface
If the media do not appear in the library you should ask in the support thread.
slash Wrote:Hmm...I don't have a Mac so I can't be very helpfull
Try this:
Thanks, unfortunately it will require me to rescan my library and loose all the watched info and stuff like that. So I'll just leave the Volumes source there I think. If you can find a way to ignore that one for XWMM, that would be great! Thanks again for your work!
XBMC 9.11 linux ubuntu
http://XBMC-ip/XWMM/default.asp just shows a white page in firefox chrome and kde
http://XBMC-ip/XWMM/movies/default.asp works to some degree but posters dont show up. my location is /home/xbmc/.xbmc/userdata/Thumbnails/Video but its looking in XWMM/cache/Video/ That location is empty. It was never populated.
It seems the part that might populate it is commented out in /movies/include.js
An alphabetical listing of movies would be nice on the left.
Thanks for your time and effort.
Few things you can check:
- XWMM latest version 1.4.4
- Look for erros in the xbmc.log (specifically http )
- Make sure xbmc user has write access to /web/XWMM
Let me know
slash Wrote:I'm curious about the c19 field, in the wiki it says C19 : [unknown].
If the C19 field is a URL, could you provide me with an example (NFO file)?
I could try to add this to the next release.
Did you give this any more thought ?
slash Wrote:Hi,
Let me know
I already have 1.4.4
I just changed the permissions on the web folder and it now shows the posters but it will only show it once for each movie. If i click on a movie it shows it , I I click on another it shows it.. etc....However if I click on any of the ones I just looked at it fails to show the poster.
Also the default url (XWMM/default.asp) still shows just a white background and appears to do nothing.
vee10 Wrote:Did you give this any more thought ?
I didn't have much time to work on XWMM this week. I was hoping to find time this week-end
FishOil Wrote:I already have 1.4.4
Just did the test and you are absolutely right. Somehow I broke something
I'll post a fix asap.
Hi FishOil,
It should work now.
Again you were right : "It seems the part that might populate it is commented out in /movies/include.js"
I didn't do proper testing when commenting this function and reuploaded the 1.4.4 correct version
Anyway, I just un-commented it for now. I'll look into it another time.
Thanks again for your help.
btw did you try the svn version ?
Regarding the earlier questions about c19, if I remember correctly this field contains the trailer (URL or path).
bertrand Wrote:Regarding the earlier questions about c19, if I remember correctly this field contains the trailer (URL or path).
So, I could add a text field with a button to view the trailer :
- the button click will open a browser window to the URL
This would be in the short term, 'cause a clean solution would be to embed the video trailer in a widget (js window).
slash Wrote:So, I could add a text field with a button to view the trailer :
That would be perfect for me, all I need is the ability to add a trailer url manually as I find the scrapers always find the wrong trailer !
Hi all,
Here is a new update :
- Added rating field
- Added trailer field with button link (not clean yet)
- Added Genre management (Add, Remove and modify)
- Moved file information into accordion (right panel)
you can dowlod it from
here or from first post.
I will be adding watched very soon.
slash Wrote:Hi all,
you can dowlod it from here or from first post.
Excellent, will try this out striaght away. Thanks for all the good work.
