whua I haven't followed recent development but what I am reading now is fantastic!
you want some suggestions? It seems the WMM already has most if not all Manager features.
Perhaps a secure area wich allows me to easily listen to my music when not at home
not really a feature a Manager is suppose to have but the Music part is already great so would be nice if I could listen to some songs.
slash Wrote:Thanks for the feedback,
I can add this in the next release but just to make sure :
- "Set" is the "movies set" ? if yes it's already planned for the next release
- Could you clarify "sortname" ? I can't find it.
- Yes, set is the movie sets. Great that it is already on your schedule...
- Sorry, I mixed this one up, it is called "sorttitle". I use this to keep the original title displayed, but have the movie / tv-show sorted on a different place (e.g. Title="Dr. House", but sorttitle="House")
Sorttitle allows you to sort movies from a movieset on whatever criteria you want.
Galefury Wrote:Sorttitle allows you to sort movies from a movieset on whatever criteria you want.
Not only in a moveset, I use it also for "normal" movies (e.g. You can have a title "The XXX" and a sort title "XXX, The") and the tv-shows...
Hey Slash. I'm trying to get this work on my home computer so I can load it from work.
I got the port forwarding set up properly so when I put in the
http://208.x.x.x:88/XWMM/index.html I am asked to sign in. I do so but then get (in IE6 Page Cannot Be Found, in FF3.66 File Not Found)
What should I do?
I copied the contents of the XWMM zip folder into C:\Program Files (x86)\XBMC\web and when that didn't work I thought maybe I need to copy everything inside the XWMM folder, including the XWMM folder itself into the \web folder. Still no dice.
I am running Win7 Ultimate 64bit and xbmc-r31951-Dharma.exe
You know of anything I can do?
The planned features seem amazing Slash - only thing you didn't mention is the ability to edit more fields for music - specifically to add a review. Will this be possible?
Other than that I just have a few Qs about some of the plans:
slash Wrote:Hi kiboy6,
Here is a list of the features planned in the nexts weeks :
- Cover and fanart support for TV-Shows and music
- image upload for movies, TV-Shows and music
Sounds great - do you plan to let users browse for local file AND/or input URL?
Quote:- visual rating (R, PG-13...) for movies
Will we be able to add ratings for movies that are missing them?
Quote:Any other short term features suggestions ?
This probably isn't short term or any term (!) but would it ever be possible to open XWMM when XBMC isn't running. That would be super cool, but I imagine it's probably an inherent impossibility.
Thanks Slash!
I've setup XWMM and it works flawlessly, just curious if there is a way to manually add new movies? I have small homemade movies that I want to add into the "Movies" list on xbmc but since there is no info on the web about them XBMC just skips adding them into the DB.
Candor Wrote:I've setup XWMM and it works flawlessly, just curious if there is a way to manually add new movies? I have small homemade movies that I want to add into the "Movies" list on xbmc but since there is no info on the web about them XBMC just skips adding them into the DB.
that a good point. I will add it to the feature list along with delete manually.
Thanks candor
kiboy6 Wrote:The planned features seem amazing Slash - only thing you didn't mention is the ability to edit more fields for music - specifically to add a review. Will this be possible?
Thanks kiboy6 for your ongoing support :-)
Yes all the fields in music should become read/write in the very short term.
kiboy6 Wrote:Other than that I just have a few Qs about some of the plans:
Absolutly. Ideally users should be able to choose: upload from local desktop, URL download, or select from within the xbmc source folders
kiboy6 Wrote:Will we be able to add ratings for movies that are missing them?
Yes
kiboy6 Wrote:This probably isn't short term or any term (!) but would it ever be possible to open XWMM when XBMC isn't running. That would be super cool, but I imagine it's probably an inherent impossibility.
Thanks Slash!
Not in the short term, but with mysql abstraction there are some possibilities if the machine hosting XBMC is up ;-)
joecooper84 Wrote:Hey Slash. I'm trying to get this work on my home computer so I can load it from work.
I got the port forwarding set up properly so when I put in the http://208.x.x.x:88/XWMM/index.html I am asked to sign in. I do so but then get (in IE6 Page Cannot Be Found, in FF3.66 File Not Found)
What should I do?
Could you do the following :
- Just unzip XWMM.zip in /web folder
- Try accessing XWMM from inside your home network
- Try removing any authentication from the XBMC interface
- Try accessing
http://ip:port you should have the default XBMC web interface
Let me know
slash Wrote:that a good point. I will add it to the feature list along with delete manually.
Thanks candor
Awesome thanks a bunch, going back and forth between the file listing and the movie mode while it works, is just tedious
I vote this should get included with all xbmc releases
slash Wrote:Hi,
- Try accessing http://ip:port you should have the default XBMC web interface
Let me know
Hey Slash,
Same result. Page cannot be displayed.
I have in XBMC > SYSTEM > NETWORK> Allow Control of XBMC via HTTP port 80 user XBMC blank password.
No dice
Galefury Wrote:Try port 8080.
Still File Not Found in FireFox
