Galefury Wrote:Joecooper84, the adress should be http://yourIP:8080/XWMM/index.html and XBMC should be active (running), otherwise won't work.
That's how I'm doing it
There wouldn't happen to be a debug log for this would there? Maybe I could see what is going wrong.
Does it for sure work with the latest SVNs?
I'm using the same versions on win7 x64 and it works.
- have you tried to access
http://ip:port (you should get the default XBMC web interface).
If it still doesn't work :
- enable debug in xbmc
- post your debug.log file (with pastebin)
let us know
Updated svn with :
- change music covers
- All music fields are now editable except (Scraper genre and year) because they never appear in XBMC interface
I got the new SVN and extracted it inside it's own XWMM folder in \web and it works! Thanks all!
joecooper84 Wrote:I got the new SVN and extracted it inside it's own XWMM folder in \web and it works! Thanks all!
Great, enjoy.
Feel free to post comments and/or suggestions.
Fantastic as always Slash.
Couple of tiny observations:
-Music genre changing seems a little funky - especially adding extra genres to an album.
- Save button for music remains greyed out even when it has become "active". (ie selectable).
-In movies, the gui makes it seem as though watched status can be adjusted for any movie, but in fact you can only change it for the currently selected movie.
Thanks Slash!
kiboy6 Wrote:Fantastic as always Slash.
Thanks Slash!
Thanks for the feedback. As always it is much appreciated.
I will have some times next week to make some changes.
Great work Slash!! Wow! Thanks for this work it is really good.
Just a couple of issues on my first test run (SVN 1.8.4 on XBMC 1:10.08~svn32246-lucid1.)
Sorry if you know about these already..
ON music management, I'm not getting images. They first show Not Available, and then when I click them I get a broken image. When I pull up properties for the image I get "http://192.168.0.5/vfs/special://masterprofile/Thumbnails/Music/7/70ed9a0e.tbn" Which is not the correct IP.
Also, on movies.. most of the flags show up great, but I have one movie that is showing broken image links. These are the properties.
"http://192.168.1.124:8114/XWMM/images/flags/mpeg%20video.png"
"http://192.168.1.124:8114/XWMM/images/flags/ac-3.png"
Again, fricken awesome work.. Thank you !
awesome work! thx man for this application. the one that i always looked for
jason32835 Wrote:Great work Slash!! Wow! Thanks for this work it is really good.
Hi jason32835,
Thanks for reporting these issues. I'll look into it asap.
ringgh0st Wrote:awesome work! thx man for this application. the one that i always looked for
I'm looking to submit it as an add-on in XBMC.
Hi everyone,
As requested here are some new features for stable and svn versions.
Stable version 1.5.3 :
- Added Cast (Actors) Management
- Added Movie sets Management
- Added sort title field
- Added Music Management
NOTE : Music covers are not displayed (too lazy to port back to XBMC 9.x)
SVN version 1.8.6 :
- Same new features as in 1.5.3 but with music cover Management
How to use Movie sets:
- Manage Movie sets (Add, remove, rename) : go to Tools / Manage Movie Sets
- Add movies to Set: Select movie go to Other details (right panel)
- Remove from Set: clear set field in Other details panel
I should start a user manual (or help file), XWMM is starting to have a lot of options
Let me know what you think.
YES !!! Movie sets management ! Thank you, slash ! Works like a charm.
The thing that would make this absolutely perfect is if it had a UI that was more iPad-ready. Right now, I can't scroll on my iPad and the UI moves off the page and won't let me shrink. An iPad-ready version would...well, hell, it'd be worth PAYING for, honestly.
Galefury Wrote:YES !!! Movie sets management ! Thank you, slash ! Works like a charm.
My pleasure
