megacrypto Wrote:i will start playing around with it a bit and let you know, but one thing i noticed is that i can not reset the info from within the manager, i.e look up the movie on imdb or so and select a different one... i did the code for that some time ago if you would like i can send it to you (and i was using also extjs for the interface)
It will be interesting to integrate your code into XWMM.
you can post it here or send to me via private message
Thanks in advance for your contribution
Flomaster Wrote:running beta1
I was able to make some changes but had to repeatedly keep refreshing the page.
its like they were being stubborn and only a page refresh would allow one change at a time
-=jason=-
Could you post a debug log of xbmc (with pastbin) cause I can't replicate your problem (running Dharma beta 1 on Karmic)
Thanks in advance
slash Wrote:Could you post a debug log of xbmc (with pastbin) cause I can't replicate your problem (running Dharma beta 1 on Karmic)
Thanks in advance
yeah let me turn on usb debugging in xbmc then try and log in using grooveshark
-=Jason=-
EDIT:here is my full debugging log with grooveshark debugging and xbmc debugging turned on
http://flomaster.pastebin.com/fjz8TZKM
Flomaster Wrote:yeah let me turn on usb debugging in xbmc then try and log in using grooveshark
-=Jason=-
I don't see a query to change the genre for an album. It should look like :
DEBUG: HttpApi Start command: execmusicdatabase paras: execmusicdatabase; UPDATE album SET idArtist = .....
Can you try with an other browser (firefox)
C:\Program Files (x86)\XBMC\web\XWMM
XBMC is running and I can get to the main web interface, but when I type in:
http://192.168.1.132/XWMM/index.html
It says "file not found"
Any ideas?
kri kri Wrote:C:\Program Files (x86)\XBMC\web\XWMM
i get the same thing on /XWMM/index.html ...
try /XWMM/
movies/index.html
As I understand, with beta 2 the web interfaces are addons.
The xbmc-web package was removed. Now you find it under /usr/share/xbmc/addons/webinterface.default/
What does that mean? Do I need to move some files around?
BurningSky Wrote:The xbmc-web package was removed. Now you find it under /usr/share/xbmc/addons/webinterface.default/
Yes, that is true but not the cause of the problems. I run XBMC under windows and ran procmon while accessing
http://localhost/XWMM/index.html and saw that the webserver tries to load C:\XWMM\index.html :mad:
Looks like a bug in the webserver.
Moving my XWMM folder to, yuck, C:\XWMM made it work but I hope it gets fixed in beta 3
Regards,
Joop
kri kri Wrote:What does that mean? Do I need to move some files around?
Move the XWMM folder to the new location and it should work again. Tested on Ubuntu Lucid x64.
Quote:Instructions:
- uncompress the zip file in your XBMC web folder
Um where is the web folder on a mac? I've looked in ~/Library/Application Support/XBMC and can't see anything obvious.
I'm running Dharma Beta 2....
Ahh no found it - have to actually go into the Application itself
I'm now having problems with the Posters. If I select a movie no poster appears, save with TV etc.
XWMM is running on the mini under my TV and I'm browsing from my laptop. If I get the address of the image that's not displaying I get something like
http://mini:8765/XWMM/cache/Video/d/d5beabb5.tbn
Which just displays File not Found if I try to access it directly.
I'm on Dharma Beta 2 and using 1.8.6 of XWMM.
