bandelguy Wrote:The music section is not saving updates I am making, I am using 2.02. Save button is working though.
I'll look into it
Thanks for your patience.
I've been trying to figure out how to change the trailer streams that XBMC picks. Someone suggested using XWMM. Looks like it should do the trick but I can't seem to get it to work. It says it saves, but then if I go back to it, it changes to the original. Im using 1.9.4
This is the video XBMC picked:
http://www.youtube.com/watch?v=j8gGoo89HV4
(plugin://plugin.video.youtube/?action=play_video&videoid=j8gGoo89HV4)
I want it to be this video instead:
http://www.youtube.com/watch?v=C8sEZAB13_o
I tried changing it to:
(plugin://plugin.video.youtube/?action=play_video&videoid=C8sEZAB13_o)
Also, is there any way to set XBMC to steam 480p if available?
EDIT:
One other thing I forgot to mention. The "VIEW TRAILER" button isnt working either. Just comes up as a blank page. Is there something I have to install to get it to work right, or does IE have to be default browser or somethin..
ThaDraGun Wrote:I've been trying to figure out how to change the trailer streams that XBMC picks. Someone suggested using XWMM. Looks like it should do the trick but I can't seem to get it to work. It says it saves, but then if I go back to it, it changes to the original. Im using 1.9.4
EDIT:
Hmm, no sure I fully understand:
- why are you using plugin:// and not the http:// url directly in the field
- getting the 480p stream trailer is done by the scrapper not XWMM so you should ask this in the scapper forum
- I'll try to replicate your error and let you know.
slash Wrote:Hmm, no sure I fully understand:
Oh, I was just using plugin:// because thats what was in there. Whatever scraper that is setup put it that way I guess. I figured thats how its supposed to be so I didnt change it...
So I should be able to just copy the regular youtube url and that is supposed to work?
I've tried using it and it *seems* like it'll be really useful, but, currently, I've only tried this with TV shows, but when I hit save, it says "Checking changes..." with a progress bar, and then... doesn't save anything. Refreshing it just brings back the old data.
Am I doing something wrong or is there a problem?
ThaDraGun Wrote:Oh, I was just using plugin:// because thats what was in there. Whatever scraper that is setup put it that way I guess. I figured thats how its supposed to be so I didnt change it...
Even when I change it to say "http://www.youtube.com/watch?v=C8sEZAB13_o" it still reverts back to:
I'm using win7 x64.
Do I have to "run as administrator" some how.
I'm looking for the zip file so I can install the add-on manually on ATV2 (I've installed the nightly build of Dec 10th). I only found a link to XWMM 2.0.0d and couldn't find a link to the latest.
Can someone provide with a link to the zip file of XWMM 2.0.2 or later?
patrickd Wrote:I'm looking for the zip file so I can install the add-on manually on ATV2 (I've installed the nightly build of Dec 10th). I only found a link to XWMM 2.0.0d and couldn't find a link to the latest.
you can download it from the first post in this thread.
Latest SVN version (requires XBMC pre-eden version)
Won't work on xbmc4xbox?
Another user here who can't save changes. Using the svn.
Fixed most (if not all) the save functions issues in movies, tvshow and music.
Let me know how it goes.
slash Wrote:Hi,
Just tried to edit an album using the latest stable and then the svn version. Neither save.
TheStretchedElf Wrote:Just tried to edit an album using the latest stable and then the svn version. Neither save.
Could you provide more info about save with the svn version.
- XBMC version
- XWMM svn version
- Which field you tried to save
I tested it, and it was working for me
thanks in advance
using the svn version and eden beta1, the album description doesn't get saved after editing, also, if allmusic.com scraper doesn't scrape the labels info, then manually editing the field, doesn't get saved.
Other features working .
